Old 10-08-2020, 10:25 AM
Default Help with diode
This diode allows 12 volts to the coil only when the starter is engaged. I need a new one and don't know what to order, I also need some kind of holder for it.
Old 10-08-2020, 11:52 AM
The drawing is more than bad, do you have a picture of the old diode.
Why the holder?
most single diodes above 6 amps are a threaded stud mount.
Old 10-08-2020, 12:35 PM
Its about 1/4" in dia.
Old 10-08-2020, 12:38 PM
The old holder busted off but I was able to make a new one
Old 10-08-2020, 03:39 PM
Found one a tad smaller and it works just don't know for how long
Old 10-08-2020, 06:10 PM
I can see some numbers on your old diode. look closely you probably can see the numbers and get the same diode.
1) picture
this is about the standard if you were comparing pictures.
diode on the right 1 amp or less
center 3 amp
left 5 to 6 amps
Going by pictures your old diode is likely a 3 amp
the one in my picture is a 1N5404 ( 3 amp at 400 volts)
I would guess the old diode is 3 amps and 400 volts minimum.
Average car coils pull 3-4 amps may want to go with a 6 amp diode.
the 1N5404 can handle a 200 amp surge for 8 milliseconds so they likely figured a second or two should be fine.
Old 10-08-2020, 06:40 PM
Thank's!!!!!!
Old 10-08-2020, 08:17 PM
If it makes a differencce this is for a welder. What do we think of this one
Old 10-08-2020, 09:26 PM
That will work
but
if you are going to purchase "new" may as well get the higher voltage rating most of the time its only a few penny's more.
here you go from your link 1000 volt rating. and cheaper
https://www.westfloridacomponents.co...ectifiers.html
Old 10-09-2020, 10:13 AM
The numbers I found are
MR
506
8848
