Old 10-01-2020, 11:52 AM
Originally Posted by Spencer View Post
I'm way too busy now to retake the class, but they automatically re-enrolled me and when I asked to postpone until this coming Winter's class, they said it was now or never for me, as I don't necessarily meet the normal qualifications to take the class.
Your tax money supports this kind of behavior ?
Old 10-01-2020, 04:39 PM
Spencer Spencer is offline
Good to see you got back into it! Get your money's worth!
I avoid stick welding because I have other options available so I'm no "pro" at it. Those welds look "cold" and was there any surface prep? Kind of hard to tell from the pics.
Keep plugging away! Practice makes better!
No prep, just freshly cut plate, right out of the shear.
Old 10-01-2020, 04:46 PM
My sarcasm meter may be off lately, so I'm not sure what you are getting at.
If you are asking if I'm likely one of the few who have started the class who has actually paid into the system that the class receives its funding from, then yes, my tax money is supporting my participation.
Back on topic, I got to do my first overhead welds this week. Here is my 3-pass fillet weld using 7018.
Old 10-01-2020, 08:31 PM
The overhead weld looks presentable. Looks like one pinhole in one edge. Edges could be straighter, but nothing burning another 50 lbs of rod will not cure.
I think you are doing good. As far as the 6010, that rod is hard to get a nice looking bead. It can be done, but the nature of the rod makes it difficult.
Old 10-02-2020, 03:02 AM
Reason I ask is there looks like mill scale there. And I'm not seeing the HAZ...
TA 95 lunchbox w/tig
Old 10-02-2020, 04:13 AM
No question on the edges being a bit all over the place. I got talked into tri-focals a few years ago and have regretted that decision ever since.
In class, I just leave my glasses off, as the 'reader' section is way too small and way down at the bottom of the lens. We also have to wear class-issued safety glasses and a surgical mask under out welding hood.
It is a wonder my welds are anything close to straight, as my safety glasses are all fogged up from wearing a mask and my vision sucks. My instructor loaned me a used 2+ cheater lens to use in my hood, which helps, but is not ideal.
I'm not saying my weld results would be phenomenal if I could actually see, but I think they would be at least a little better. I landed a big project that started the day after Labor Day, which is making it challenging to do things like make an appointment to get new glasses, but I am going to try to do so in November. I'd like to get some prescription safety glasses in both single-focus standard vision and single-focus readers.
Shoot, now that I've typed that out, I wonder if someone makes single-focused safety glasses with various standard power lenses like those cheap readers you can pick up at almost every store?
Old 10-02-2020, 07:32 AM
camdigger's Avatar
Roving Reporter
Yes. Do a google search. Here is a Canuck supplier of Uvex safety glasses. https://www.uline.ca/BL_1262/Full-Lens-Safety-Readers
The selection of powers is limited, but other suppliers may have more selection.
Old 10-02-2020, 10:19 AM
Norm W's Avatar
Norm W Norm W is offline
You could do what I do. I have a cheap pair of readers that I put inside my regular glasses. The prescription classes take care of the astigmatism etc. and the readers (in different strengths) takes care of the change in focal length. The closer you are to the work the higher number for the readers. Standard arms length is 1.5, at 10" I use 1.75 and for splinters a 2.25. YMMV
Old 10-02-2020, 12:50 PM
Get a cheater lens for inside the hood. I use one and it helps me.
Old 10-05-2020, 10:28 AM
Just as I asked it, they sound to be threatening you with kicking you out
from the class.
Why ?
And why would you put up with that behavior ?
