Old 08-11-2020, 08:38 PM
Default Scott's New Shop
Met with Scott's septic/concrete contractor to go over water, sewer and power penetration locations in preparation for trenching and running the utilities. Contractor is doing the trenching. Tomorrow morning we head to Menards to do some shopping for water line, septic pipe, and toilet and shower flanges. Son and I will put in the interior utilities. Contractor will connect just outside the shop walls.
Old 08-11-2020, 09:34 PM
Planning on a 3" toilet flange then to a 4" PVC pipe to go outside the shop wall to connect to the 4" PVC going to the septic. So question is to do the 3" to 4" right under the 3" flange or just before exiting the outside wall of the shop.
Old 08-11-2020, 09:58 PM
Clean out fittings??
Old 08-11-2020, 10:07 PM
Yes. One just outside of the shop and one half the way to the infiltrators for the septic.
Old 08-11-2020, 10:28 PM
I would stay with 3" inside. If I am correct the velocity will be higher in the 3 inch and a turd can be left behind if the water flow is too shallow as in a larger pipe.
In this area 4 inch is commercial application where you have more users in this area. My old septic line for the demolished house left the basement as 3" copper and went to 4" ABS and then reduced to 3" going into the tank.
Old 08-11-2020, 10:54 PM
Here 3" used to be the standard. Just a few years back they all switched to 4". I expect they have changed the slope when they switched to 4". It is 1/8" per foot now.
Old 08-13-2020, 02:34 PM
The crew to do the concrete started on forming and trenching. We got some of the electrical conduit and wire done today. Put in 60' of 1 1/4" PVC water line. Trenching not yet done so back at it tomorrow morning doing the septic. Got the plastic barrel drilled with a series of 1/2" holes and 1/2 full of 3/4" gravel. The floor drain 3" pipe will be cut to grade after they do the trenches for the footers and fill in the floor drain barrel. 103F today.
ID:	157264   Click image for larger version
Old 08-13-2020, 03:15 PM
Floor drains are legal there?? Not here. When you form the floor drain make it wide enough for a shovel, it makes it a lot easier to clean, not that I would know that for sure
Old 08-13-2020, 03:22 PM
I filled mine with rock and had holes all around and up to the top of the barrel
Old 08-13-2020, 04:09 PM
Legal Smeashal, who gives a shit. No forming, just a 3" PVC pipe and PVC top grate. Did one that way for my brother 30 years ago and it is still working fine.
This has holes all around up 3/4 of the way. Concrete crew says no problem.
