Old 07-02-2020, 08:07 AM
JWS's Avatar
JWS JWS is offline
When we added onto the house about 18 years ago (maybe more) I put green tin on the roof over 1/2 OSB. No problems. Old part of the house put purlins over asphalt (two layers) and screwed down green tin. Was told the same thing about the expansion and contraction against asphalt scratched the underside causing the roof to rust out from bottom up. I went single sheet from top to bottom.
Old 07-02-2020, 08:31 AM
What problems would you have? Excessive sunlight? It never rains in AZ...
We get about 6” of rain a year, most of it in about an hour during one storm.
Old 07-02-2020, 09:20 AM
Thanks for all the input, as always a lot of experience here.
I will likely hire some kids for the tear-off.
The deck is currently 1/2" CDX, would putting down a second
layer of 1/2" CDX be worth it, I would glue it and screw it down.
Or is that just a waste of money.
I think it is a bit excessive.
Old 07-02-2020, 10:04 AM
I would replace any questionable decking and go with what you have . You got what 1-2 years before move .
Old 07-02-2020, 10:14 AM
flametamer's Avatar
During the roofing job, no less than 2 local places burned to the ground, the fire chiefs blamed the steel roofing job, with the purlins created a airspace
that they couldn't get water to, filled with dried out shingles.
While that would have contributed to being unable to extinguish the fires, that had nothing to do with causing a fire. -Side note-the worst house fire I've ever worked started in the attic of a clay tile roofed house. The tile acted as an insulator, would not let the fire vent, and also hid the location of how far the fire had spread.
Dt
Sero Sed Serio
Old 07-02-2020, 10:22 AM
Originally Posted by midmosandblasting View Post
Good luck. Potato forks work ok. If you were closer I would loan you the roofer shovels . I'm to old and fat to be climbing on roofs anymore.
Thanks, no worries if "do it myself" I will buy a couple of stripping shovels
and hire some youngins to do the hard part.
Old 07-02-2020, 10:24 AM
Yeah, maybe a bit more, Covid, changed some of mgt. thinking...
Old 07-02-2020, 10:26 AM
Dully noted.
Old 07-02-2020, 10:28 AM
I should be okay there; as I replace a lot of the plywood last time I had the roof off as I knew there were issues.
Old 07-02-2020, 11:21 AM
Dt
So it's Okee Dokee then to just be a slacker and blow a tin roof on top of all that crap ?
