Old 03-02-2020, 01:15 PM
Originally Posted by JavaKing View Post
I have a flux core welder and need to weld a 3/4 copper pipe. I do know that most people say no to this type of welder, but this is all I have to work with, know other way. Is there a wire that I could try that might just get me threw this time.
I was going to use map gas but would not get pipe hot enough to melted the silver copper brasing wire pipe is copper refrigerant line OD 1 inches
Okay, too many nice guys on this forum. That is not me.
You clearly do not have the knowledge, skills or equipment to do this job.
If you do buy the wire that dubby posted, you need Argon to run it. You state
you only have a flux core welder. Also you will need 145-185 amps to run
that wire. I am gonna guess you don't have a machine that can reliably
deliver that amperage. Copper alloys need a lot of heat to weld. I suggest
you get a oxy fuel rig to properly braze copper alloys. Propylene will work or
acetylene, if you are buying new I would go Propylene.
But with where you are at, do you really want to tackle brazing 1" refrigerant
lines. I strongly suggest you hire a professional with the right equipment and
training. Clearly this is a commercial application, are you willing to take on
the liability? Are you insured for this type of work?
https://www.harrisproductsgroup.com/...-GMAW-MIG.aspx
Old 03-03-2020, 10:47 AM
JBFab JBFab is offline
Thank God, finally a voice of reason.
Old 03-03-2020, 11:57 AM
Oh, I think a number of people would disagree with you,
but will enjoy the vote of confidence while it lasts!!!
Old 03-03-2020, 12:20 PM
Suck up!
Old 03-03-2020, 12:29 PM
Suck up!
Brian, don't do that when I am eating, now I have to clean off
the ham and cheese sammich from my monitor...
Old 04-11-2020, 09:23 PM
Will not hold pressure on a 1 inch OD refrigerant line
I know some folk like to tackle the unknown, but geeeewizzzzzzkers.
I'd love to see a pic of what type of system he's working.
Must be a Russian Shuttle?
Old 04-12-2020, 12:03 AM
monckywrench's Avatar
trust but verify
Good advice though if OP is determined he could braze a bunch of fittings for practice first. Paying a pro would make the most sense as the pro can backpurge the line which I suspect OP cannot, then pull a vacuum before charging. If he doesn't backpurge his joint could be compromised. My HVACbro purges as a rule and he's been at it a few decades.
It's worth buying the equipment since it pays off over time. My trucks I fixed paid for my vacuum pump, nitrogen regulator etc. I've leak checked using shielding gas (same CGA-580 cylinder valve so why not?) which costs more than nitrogen per cylinder but pressure test or purging doesn't use much gas. My HVAC bro showed me how to troubleshoot my heat pump, and since he's a friend I paid him to swap the compressor, contactor (he always replaces contactors and motor capacitors with every compressor change which makes perfect sense, my contactor still worked but when I broke it open the contacts were toast) and dryer and charge the system. Next time I'll do it myself since it's easier access than auto AC. I encourage any weldor to do their own HVAC work on basic systems as there's plenty of info out there.
I have both LP/polypropylene and acetylene regulators and since I use acetylene for gas welding I'd get an acetylene regulator unless I needed serious LP or poly flow, but for someone just heating/brazing/cutting LP/poly are more than adequate and the ability to run more pressure is nice. So is grabbing a BBQ jug for portable work.
BTW the main difference between an LP/poly/etc rosebud and acetylene rosebud is the LP versions protect the easily blown-out flame from disruption. Before I scored some LP rosebuds I figured out I could shorten then slot an old Tweco MIG nozzle and clamp it to my acetylene rosebud leaving about 3/4" extending past the rosebud tip as a "flameholder". Works fine and I still have it. I could probably shorten the nozzle to ~ 1/2" but didn't bother since it works as it should. I think I posted it here a long time ago.
Useful place to lurk and learn: https://www.hvac-talk.com/vbb/
Old 04-12-2020, 08:06 AM
Like adding a hot tap for your house from a nearby 36" 2000 psi transmission
line "when nobodys lookin'..."...
Old 04-12-2020, 01:59 PM
The OP decided on Brazing with a new question.
brazing copper tubing need rods
https://www.shopfloortalk.com/forums...ad.php?t=51786
Old 07-12-2020, 09:30 AM
I had a similar idea as a possible method of powder coating a large piece without an oven but never got around to trying it yet.
Hmmm, wonder if the welder could be used to heat the pipe to melt the solder? Basically no wire at all in the welder, and short out the gun tip to the copper pipe with the ground clamp attached to the pipe, and pull the trigger. Might sacrifice a tip, but might work, if the welder can hold the output.
