Old 02-29-2020, 09:02 AM
JavaKing JavaKing is offline
Silver solder might feed
You may have a good idea might be a task finding .030
Wire and silver so expensive
Old 02-29-2020, 09:08 AM
.030 silver would be very expensive if I could find
Old 02-29-2020, 09:36 AM
Twice the size--half the man
I've never used it or tried it, but google says you can use Silicon Bronze MIG wire. I've always just soldered stuff together but hey, I'm interested to see how it works. 2# spools of the stuff are only $30 so that might have to be a project for another day.
Name:	Annotation 2020-02-29 083612.png
Wade's Custom Kydex
Old 02-29-2020, 12:29 PM
Originally Posted by JavaKing View Post
I was going to use map gas but would not get pipe hot enough to melted the silver copper brasing wire pipe is copper refrigerant line OD 1 inches
You must have an old Torch or it is the small one, MAPP may require changing jets.
https://www.shopfloortalk.com/forums...ad.php?t=18216
Old 02-29-2020, 02:31 PM
Will not hold pressure on a 1 inch OD refrigerant line
I find that very hard to believe. If by some chance regular solder won't hold then silver solder would work for sure. Any form of mig welding is just ridiculous. If you don't trust either regular solder or silver solder then you might try tig welding with silicon bronze rod but it's still the wrong process...
Old 02-29-2020, 02:44 PM
If you are doing a sleeve connection any acceptable solder will be stronger than the parent pipe. if it is a butt joint good luck.
If vibration is an issue a decoupling section of suitable hose is the key.
Old 02-29-2020, 03:10 PM
According to the net, silver solder is over 70,000psi strength and melts at 1,145 °F.
Old 02-29-2020, 04:08 PM
Silver solder is a generic term like big mac.
Silver solder should be called silver bearing solder.
The exact metallurgical composition determines all of the characteristics of the sample such as melting temp , wetting characteristics and the correct metals to use it on.
It is very much like welding rod most will make a weldment but best results come from using the correct rod for the job.
Old 02-29-2020, 05:31 PM
You can't doo every job with a hammer & duck tape.
Sometimes it's best to farm it out.
Clearly this is such a case.
Old 02-29-2020, 06:48 PM
Most HVAC guys are using the silicon bronze with a turbo torch . On Heat Pump systems . At least around here .
