Old 12-13-2008, 09:26 AM
Originally Posted by Mith View Post
Looks like its a 300A welder? If so, you'd never get that output from a single phase welder.
Now now, I have 2 welders that are 300A and 400A and run quite nicely off
single phase.
I change the title to better reflect the topic. Aids people searchin later.
Old 12-13-2008, 09:32 AM
Mith Mith is offline
But you guys have high amp single phase outlets. Over about 16A here we go 3 phase.
Jim
Old 12-13-2008, 01:23 PM
Originally Posted by OTTO1976 View Post
Has three wire plug.....Have not seen inside....the migatronic website is where i found the manuals for the 3 phase versions.....Its so weird...The exact welder is in the manuals but only this one is single phase. And nobody seems to know where this single phase version came from.....For all you Google saavy guys. Heres your true test. I have scoured, no luck. Here are ALL the pics....looks like a good machine...
I'd check on the meaning of phase in Europe.
In Mexico, (and that would mean Spain as well because there is a huge trade and investment between them) 3 phase means 110/220 single phase. Read "wire" for phase. A 2 phase house has only 110 power and a 3 phase has 110 and 220 available. When I hooked up power in Mexico I had the same headscratch to figure that one out.
Three phase as we know it, is 4 wire... er phase Metalworker could probly correct if I am wrong.
Old 12-13-2008, 04:42 PM
monckywrench's Avatar
trust but verify
Maybe someone on these forums would know?
http://www.mig-welding.co.uk/forum/index.php
Old 12-13-2008, 06:09 PM
Yup we do... I have 20, 30, 40, 70 and 100 amp 230V single phase outlets, in my shop. Put the 100A outlet for the Dynasty 300DX.
Old 07-23-2020, 10:46 AM
gdowie gdowie is offline
Default To help anyone else out with this welding machine
Hey everyone, I realize this is a long dead post, but I acquired the exact same machine (Migatronic BDH 320 Commander Triple) and faced the same issue. Manual states 3 phase required, but plate on back indicates single phase is possible. Well long story short: after much tinkering I am happy to report I am successfully able to use this machine to it's full capability on US single phase 240V mains. Here how it's done:
1) Wire L1 and L2 mains to contactor, through the provided blue wires, being sure 2 small AWG brown wires are on terminals receiving power at all times, even when contactor is not engaged. Neutral on 3rd contactor post. Ground to chassis ground per usual. The two small brown wires should go to the front panel switch.
2) Move 2 black wires coming from front panel switch to the 230V posts on the distribution terminal block in the front of the machine. These terminals should have Red and Black distribution wires coming from them.
3) In the bottom left hand corner of the main PC board for the inverter, notice that there is a jumper. This tells the controller what voltage to expect. Remove the jumper (no contact); and move it to jump the J1 contact near the upper left of the same PC board.
I just wanted to post this info somewhere it might help someone else! I expect a similar procedure will allow it to run on 380V 3 phase as well as 400V and 440V.
Old 07-23-2020, 10:58 AM
Originally Posted by gdowie View Post
Hey everyone,
Thank you and welcome to the site.
Old 07-23-2020, 05:47 PM
Hey everyone, I realize this is a long dead post...
No problem with the necropost--great of you to update it with your experience!
Excellent first post! Welcome Aboard!
TA 95 lunchbox w/tig
