Capacitor Mod on Astro pocket turbo 130
Ok, all you electrical gurus. I am in need of some help deciphering the schematic and I am stuck on a question.
I will be adding a 100000 uF Capacitor 50 V to this welder. I have pretty much figured out the connections for it and the bleed resistor. I am having a problem with the additional bridge rectifier connections. The pcb and drive motor in this unit get voltage from the gun when the trigger is pulled. Now how to wire in the second rectifier to isolate the pcb and drive motor and not fry them when I pull the trigger. The person who sent me this diagram added a euro torch to his and it has a two wire lead from the gun where mine is a single lead. He also added a 120 gas solenoid, since the old torch had a mechanical valve in the handle. I don't want to replace the torch if I don't need to. Any Ideas? Ken
There are 10 types of people in the world, those who speak binary and those who don't. |
Here are a few pictures of what his looks like all done up.
Ken
By adding the capacitor,the drive motor runs extremely fast, and the speed adjustment has no effect. The cap affects the speed controller. Adding in the second rectifier acts as a isolator and problem was solved.
They also added another 100uf 35V capacitor to the wire feed motor to help smooth the wire feed a bit. Ken
It's getting late so I cant go into details.
You could probably add a relay. have your gun trigger the coil and the normally open contacts of the relay connected to the two trigger wires on the new drawing. may have to add a resistor to a 24 volt relay. adding the larger cap probably brought the voltage up around 35 volts. As for the new motor capacitor, looks like they have its polarity marked wrong and it should be more like 50 volts or more
"Actually the motor negative is going to the negative on the bridge, but the way the original diagram is drawn, appears to connect to the positive, maybe I should have redrawn it to show it passing past the positive connection. I didn't draw the original diagram, it was a download from manufacturers website" His words. Ken
I'm tied up this morning to make you a drawing, maybe around 1pm.
you should be able to add a relay and use the gun you have. you would remove the two wires A3 and A1 (old drawing) ,and use them to power the relay. Use the two relay contacts to trigger the two wires (gun) as on the new drawing.
Here Ya Go
Here ya go, Hobby! It's very straightforward. You're just duplicating the rectifier and filter of the first gun. Make sure to heat sink and cool the rectifier module with a fan. I've often thought I'd like to do the same to my MM180 so I could have my spoolgun always attached but I'm too lazy to plumb the gas fittings!
If I ever do it, I will bolt a metal box to the top of the welder and run the DC, Gas and control voltage to it. That way I won't mar the beautiful miller front panel and I could always restore the welder to original condition. DrBob |
It's ok to tap off the AC side and feed a second bridge, but in your drawing the minus sides are connected to both bridges. You can not connect the plus or the minus sides of one bridge to the other.
