Old 03-13-2019, 10:54 AM
digr digr is online now
LOL let your fingers do the walking! Do you know if those square collets fit both cold and hot rolled square stock?
Old 03-13-2019, 11:14 AM
Ted,
Not square and hex collets, square and hex collet blocks. They allow you to machine squares, hexes or parallel sides on round stock, when the blocks are used in milling machine vise. These use standard ER 32 style collets. Similar to the collet block sets sold for the 5C series of collets.
Old 03-13-2019, 12:17 PM
EBay sale, Rocky Mountain CNC Solutions in Colorado Springs, Colorado.
$20.50 with free shipping.
Look up Er 32 ball bearing nut
Found one for $16 free shipping. It is on the way. Got a wrench also.
Harry S. Truman
Old 03-13-2019, 02:08 PM
Ted,
I see I missed the block part, Those will come in handy, no need for a indexing head, I have t Syoz 25 collets.
Old 03-14-2019, 08:07 PM
I spent the last 2-3 hours, with a bright light, a pick, razor knife, tiny needle nose pliers and a stack of business cards, the set about cleaning every slot in all of the ER 32 collets. The amount of swarf, slivers and slime that came out was amazing. I cleaned all the collets with brake clean, cleaned the slots, did an aggressive bout of high pressure air cleaning, then a shot of rust preservative, then back into the little plastic bag and the collet sleeve.
Old 03-14-2019, 08:34 PM
Good idea. I will do the same when mine get there.
Harry S. Truman
Old 03-18-2019, 03:19 PM
Welp, the finishing pieces of my EBay order arrived, the two ER 32 wrenches (4 point style), showed up this afternoon. Damn!! I’m ready now!!.
So now I’m down to 4 pendings orders, a carbide insert order from ISI Direct, a threading tool from VME, a small order from LMS and a vise parts order from Shars.
Maybe 4 pending is wrong, I forgot about the ER 32 collet blocks and ball bearing nuts.
I have a possible large Korean end mill purchase in the works.
I’m wondering if I can claim some of the machine tools as dependents, on my taxes.
Old 03-19-2019, 09:16 PM
Got my ER32 ball bearing nut today, and my 4 point wrench. Very nice machining work on the nut. Threads are very smooth. Is the tiny hole on the bottom side side of the nut to lube the bearing?
Harry S. Truman
Old 03-20-2019, 10:08 PM
Took a needle and found the tiny hole does not go through to the ball bearings. So oiled by turning the inner collar with oil at the seam. It did go down through the gap between the two pieces and ran smoother.
Harry S. Truman
Old 03-22-2019, 09:13 PM
Well Jack you caught be in a weak moment. Ordered this from Banggood today. Did get $5 off by using some points.
Now no more opening the top cover and reaching up to change cutters.
Ordered on the 11th, reached CA on the 13th, took 9 days to get to NV. Still waiting.
Harry S. Truman
