  #671
Old 03-15-2019, 02:37 PM
OldRedFord's Avatar
Kibble King
Should I look into LED lighting or run with the used high Bay fixtures I got at $1 each? They take f54T5Ho bulbs. 6 per fixture.
Tim
  #672
Old 03-15-2019, 03:49 PM
Scotts Scotts is online now
The t5s can usually be put in 1 bulb at a time to run a fixture. What is the price difference?
  #673
Old 03-15-2019, 07:54 PM
randydupree's Avatar
Why, Hell Yes!
By the time you get the building built there will be some new fancy shit that makes power!
Sorry Tim,you left the door wide open!
  #674
Old 03-15-2019, 09:23 PM
Tim,Figure your draw on currant .If payback is to high of time frame ,phase in the led as the others die .Cost of ones you have times expected time running to get Kilowatts .Led cost plus electrical usage . I am betting best net dollars is what you have . Always figure life cycle cost of ownership .
Last edited by midmosandblasting; 03-15-2019 at 09:25 PM. Reason: added life cycle
  #675
Old 03-16-2019, 08:09 AM
Why, Hell Yes!
I think wire size and cost has to come into this somewhere too.
I bought portable shop lights on sale at Costco and i used cheap extension cords from Horrible freight to connect them,just plugged them all in.
The lights came with a bracket so you can screw then to the wall or whatever.
  #676
Old 03-16-2019, 03:38 PM
If they are permanently wired In Canada the code requires minimum # 14 wire for all external runs. Wiring supplied inside the fixtures is covered under a CSA sticker or equivalent. I believe that the NEC has similar requirements.l
  #677
Old 03-17-2019, 09:34 AM
No.
We started building our new warehouse at work too. Also a self build. There's a bit of teasing and shit talking going on. . The warehouse is sitting on almost sixteen feet of fill at one end.
I tried to pack the dirt with the D8 but the grousers just chew everything up. I guess the opposite extreme of a mini ex.
If the dirt is not too thick, and you never turn the cat on the compaction site, I have seen a D8 pack ground so tight that the grousers would not sink in more than a 1/2 inch. A certain level of moisture is needed to lubricate soil grains when packing.
If you are trackpacking, i imagine you know already....but use only 6-12 inches of dirt at a time to be effective and keep adding layers.
If it were me and the 16 ft of fill had not been compaction tested by an engineer as it was built up, I would not put a lunchroom at that end of the building. It should set for a year.
About soil compaction
Aaron Neville
  #678
Old 04-23-2019, 09:23 AM
OldRedFord's Avatar
Kibble King
Fingers crossed this weekend I'll do a air test of my drain lines prior to reinspection. After that passes it's onto concrete finally.
Tim
  #679
Old 04-24-2019, 07:21 PM
Why, Hell Yes!
Good luck kid,its been a long wait.
  #680
Old 04-24-2019, 10:13 PM
As they say, patience is a virtue.
Harry S. Truman
