SFT Search: |
Thread Tools | Display Modes |
Good luck. https://www.google.com/#q=Greenlee+DB-9S
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it." “The thing about quotes on the internet is you cannot confirm their validity” Abraham Lincoln |
Those panel punches are expensive but professional. If you get one, be sure it is the correct one. Many refer to these as "DB" connectors, but they're "D connectors" with different letters/numbers.
I have punched small holes in thin steel using nothing more than a sharp, flat-faced pin punch. Trick is to put the sheet on a piece of end-grain scrap wood. A hard whack with the hammer deforms the wood and drives the slug into it. It's a whole lot easier to make a 1/4" hole this way than drilling thin sheet metal.
USMCPOP Last edited by USMCPOP; 12-13-2013 at 04:53 PM. |
Everyone should have one.
Not production but this one works good, if you want rounded corners then drill the corners first. http://www.ebay.com/itm/NIB-Original...#ht_252wt_1081 Quote:
http://www.l-com.com/d-sub-punch-db1...e-greenlee-231
The part i'm using has 3-rows, which is not shown in your pic. I thought it's called DB-15, but you may be correct. Aka D-sub 15. Even McMaster-Carr calls them "DB", and they make special punches just for it. $200! Hoping for a less-expensive option. http://www.mcmaster.com/#knockout-punches/=pslrz1 Quote:
Sorry, Johnny, I edited my post later to add the punch comment. You might be able to make a square-ish punch that will do the job, but you'd have to whack it pretty hard.
I guess you have a DE-15 VGA connector. These are pin punches.
USMCPOP |
Take a 3/16" drill and drill a pilot hole straight down the center for 1/2" or so. Now take a 9/16" drill and carefully drill into the pilot hole far enough that the corners of the3 square stock are sharp edges. Done. You can use mild steel, but cold rolled is better and I would not worry about hardening it. When you need to sharpen, touch it up with a 9/16 drill bit. You can get fancy and make a squre hole for a female die, and mount a pin in it. That way you can drill a pilot hole in the sheet metal and put the pin through, and using the center hole in the punch be guided into the square die hole, but I would say piss on it and punch through into a piece of end grain firewood.
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
wow, amazing tute!!!!
this might just be our option. what equipment do you recommend for drilling? if that's all there is to it, why do they cost so much money to buy? can you think of a way to achieve a rectangular punch? THANKS! Last edited by johnyradio; 12-13-2013 at 07:01 PM. |
Is the hole in the flat, bottom (top) of the plate, or in the curved side of the plate?
on the flat
One other question that comes to mind. can you remove the nuts and pull the metal shield off? If so, you could clamp that end cap in between the main body and the metal shield. Would take a bit of the tedium out of this. I too would talk to a few of the companies mentioned. You are a non profit, tax year is coming to an end. Companies are always looking for that last bit of corporate savings.
MAGA |
Tags |
aluminum, cut, drill, punch, sheet |
