Old 01-15-2020, 10:34 PM
gimpyrobb's Avatar
Default Ancient Ingersoll Rand 7t compressor
I don't know why I brought it home, guess cause a buddy has a compressor hes outgrown. It a 30t series and with a 7hp motor it should be rated around 25cfm. This sucker was made in the 50s so I'll probably have to hydro test the tank. The motor was 3phase so I'll probably swap it out. Finally the compressor has a "loose spot" best I can describe it while rotating the flywheel. Should be interesting to see what it is when I look inside.
Old 01-16-2020, 10:17 AM
Should be a compressor that will last you a lifetime!
Old 01-16-2020, 10:56 AM
I have one like that, sitting around for stock. Mine is 3 cylinder.
The specs are:
Ingersol Rand 30T
Ser # 111622
25-30 hp
85 cfm at 1030 rpm
90 cfm at 1200 rpm
Old 01-16-2020, 05:20 PM
gimpyrobb's Avatar
Yeah, there is quite a few models in the 30t series. They started the 30t group back in 1929 and they haven't changed much over the years. Really happy to have it. I'll try to get good pics as I go through it as the 7t models aren't as plentiful as some other models.
Old 01-16-2020, 07:39 PM
alchemist's Avatar
I've got one made in 1929 and I still use it as my main compressor. The unloader was destroyed and one of the rods were bent when I got it. I just use an un-loader on the pressure switch and straightened the rod on the press.
Old 01-16-2020, 08:23 PM
LOL good job!!!!
Old 02-11-2020, 03:00 PM
gimpyrobb's Avatar
Took mine apart today to see whats going on. Man has this thing been neglected! Lots of sludge to clean out and it fought me every step of the way. One of the things I love about this old stuff is its made to be quality, not how cheap can we make it and it last for a couple years. So far, it seems the only thing it needs is bearings for the crank to the housing. The rod bearings look great. I'll post some pics up in a bit, the cell phone is charging right now.
Old 02-11-2020, 05:48 PM
gimpyrobb's Avatar
Some pics. The crank had NO interest in coming out of the housing. After trying pullers and impact hammers I found a bearing press cup for dual axles that was the same size as the bearing and whailed on it with a 5lb sledge. It finally let go and I took the crank over to the 20 ton hydraulic press to get the bearings off.
ID:	154761   Click image for larger version
Old 02-11-2020, 05:54 PM
gimpyrobb's Avatar
As you can see, the bearings are kinda crusty. Its amazing how hefty all the parts are. I took the cyl heads off with the pistons and connecting rods still in them. It was all I could do to move the large one from the driveway into the garage. The flywheel weighs a ton on its own and the intercooler is no joke either!
Old 02-12-2020, 09:33 PM
gimpyrobb's Avatar
Cleaned up the bearings, wow the larger of the two is kinda spendy!
ID:	154785   Click image for larger version
