Old 08-07-2019, 02:33 PM
Default lawn mower
Anyone know of a easy way to make rollers 2" in dia with some being 8" long
Old 08-07-2019, 03:31 PM
Rob65 Rob65 is offline
Would 2” diameter tube with bosses pressed into the end work for you?
Can make em any length needed this way without the complications of deep hole drilling.
Are they going to be plastic or steel?
Rob
Old 08-07-2019, 04:17 PM
That would work but I would rather have plastic of some kind, I guess I could do the same thing with pvc pipe, thanks
Old 08-07-2019, 04:33 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Instead of PVC, I would think HDPE might be tougher & take more abuse.
Old 08-07-2019, 04:47 PM
That, and maybe a higher schedule pipe for the extra wall thickness... Steve
Old 08-07-2019, 04:53 PM
Its seems hard to find rigid pipe
Old 08-07-2019, 07:55 PM
Scotts Scotts is online now
Try hollow rods on McMaster and see if it stirs your interest
Old 08-07-2019, 08:22 PM
The sure are proud of their plastic
Old 08-07-2019, 08:32 PM
Stack-O-Pucks with a hole drilled thru the center.
assemble on shaft and spin against a belt sander
Old 08-07-2019, 08:52 PM
Yep
