Old 05-28-2019, 03:08 AM
Default What is it going to do? Special Tool Fab...
Needed to make a tool. I thought I'd see if anyone can figure out what it is for. I'll give it a day for wrong guesses or correct answers then update. HINT: automotive-related...
Started with a piece of 2"x1"x1/8" rect. tube steel from the scrap pile. About 9"--I didn't measure it. Didn't bother cutting it either, just cleaned up the "end" end so it wasn't sharp from the steel mill. The other end drilled and cut as shown. I had to cut a little more off after fitting. Then hit it with the flap disk.
Broke out the scratch TIG TA95 Lunchbox. #17 torch. Easier than the MM140 as the C25 was buried behind some tires. The Ar40 was just under the bench. In the middle of about 20 projects so didn't even clean off the bench to do it... Took longer to setup (2min?) than to do the 2 tacks. Longer bolt holding the nut in place.
Little welder works good. Decent for stick, as well. Highly recommended if you see one used for $200 or less.
I'll update in a day or so...
ID:	150929   Click image for larger version
ID:	150930   Click image for larger version
ID:	150931   Click image for larger version
ID:	150932   Click image for larger version
Old 05-28-2019, 04:48 AM
I am assuming it is going to press something out, in, on, or off... possibly that. Or, it's a really odd can opener
Old 05-28-2019, 05:23 AM
Tie rod press, for your special cars.
Old 05-29-2019, 08:36 AM
It is a wiper arm removal tool. I have a "special" tool from one of the trucks but only succeeded in bending it. Wiggled and rocked and twisted and tapped but the arm still wouldn't come off. Needed to remove arms to get the cowl cover off.
The 3rd picture is staged after because I forgot to take a pic of the tool in place but the order is correct. Note the cowl cover has been cleaned and treated--no more nuts and berries...
Last pic=success! Turned bolt about 3/4 turn and "tink", off came the arm!
ID:	150953   Click image for larger version
ID:	150954   Click image for larger version
ID:	150955   Click image for larger version
Old 05-29-2019, 12:18 PM
Gotta love it when a plan comes together.
Woodrow Wilson
Old 05-29-2019, 12:33 PM
I guess I weren't too far off other than maybe the can opener
I'll have to remember that one for when I come across a stubborn wiper arm
Very good tool idea not to mention it's basic and simple providing one would have the other tools to make one...
Yes Indeed... looks to have performed as intended that's a win, win IMB.
Old 05-29-2019, 03:04 PM
I meant to point out how I had a nice "pointy" bolt already to use as the pusher... Metric bolt for a metric car!
Old 05-31-2019, 09:31 AM
"What's it gonna doo" ?
It's gonna get a coat of paint, that's for Sure.....
