Old 05-23-2019, 04:50 AM
I never preheat. I find the smoothness of cut is all about consistency of speed, distance from surface, and the correct sized tip for the job.
If you don't jerk and wallow and tilt the torch tip at right angles to the direction of cut it comes out nice. That is hard for some to do because age is stealing our skills.
Yep, yep, I know all about that and now as your, saying age is stealing our skills I guess that is where when it really doesn't matter and just cutting it is all that matters just getting it cut is a win sometimes
But as Walker said too "plasma cutters" is the way of life for a lot of us now. it as well takes away from the skill and art of cutting with O/A gas.
I have to cut a piece of steel I look over at the O/A torch and then the plasma and well I'll grab the plasma over the gas torch... it sort of getting left to the wayside but I still won't get rid of it... may not be the need as much as use to... but there will always be a need to have an O/A set handy cause you will find the need for it... that a plasma is just not a suitable tool to use.
Old 05-23-2019, 06:52 AM
...I have to cut a piece of steel I look over at the O/A torch and then the plasma and well I'll grab the plasma over the gas torch... it sort of getting left to the wayside but I still won't get rid of it... may not be the need as much as use to... but there will always be a need to have an O/A set handy cause you will find the need for it... that a plasma is just not a suitable tool to use...
Absolutely. We don't use our O/A torches nearly as much as we used to but there's no way we could run the shop without it...
Old 05-23-2019, 07:30 AM
camdigger's Avatar
Roving Reporter
I don't preheat, but I have been known to raise a burr with a chisel to start a cut if one is handy. It shortens the time for it to heat up so the cut can be started.
Sadly, most times it would take more time to gather up a chisel and hammer than the time it takes to start the cut.
Old 05-23-2019, 09:20 PM
I preheat to remove any surface moisture and to remove mill scale prior to layout.
Old 05-23-2019, 09:53 PM
Camaro Zach's Avatar
I am going to have to try that, thanks!
I clean/swap tips almost every time I grab the torch to just to size the tip accordingly.
I hand cut some 2” plate recently with satisfactory results. No preheat other than burning the scale as others have mentioned. In the spot I couldn’t start on an edge I did drill a 1/4” through hole though.
Buggy
Old 05-24-2019, 02:17 PM
Gerry and I have the same thoughts.
If you have to preheat you need a bigger tip. I have cut up to 4" plate,
no preheat needed, but earplugs helped.
Old 05-24-2019, 02:22 PM
Another boobtoob video on how not to do something. With all the preheat
his top edge is rounded over... My chief in the Navy would be chewing his
ass...
Old 05-24-2019, 08:39 PM
ass...
Yup, that is a problem I have with my simple little CNC table cutting 3/4" or thicker.
I have to run the preheat up high to get started, and don't have the fancy
5 regulator system like the fancy machines to drop the preheat after pierce.
So I doo get more round over than I would like.
Old 05-25-2019, 10:02 AM
Originally Posted by Camaro Zach View Post
...I clean/swap tips almost every time I grab the torch to just to size the tip accordingly...
Having a clean, properly sized tip makes a huge difference in how well an O/A torch works. Back in '69 when I first started hackin' and tackin' metal most small shops didn't have the options for cutting steel that are available today. No plasma, laser or waterjet cutters; abrasive saws were pretty much confined to larger shops, zip discs didn't exist and bandsaws were few and far between. Other than an O/A torch a cheap, import power hacksaw was probably the first metal cutting tool that most of us had.
We had to learn how to use a torch properly; selecting the right size tip, keeping it clean and knowing how to start a cut with minimum preheat were basic skills. We had to because there often were no alternatives. Today, while we still keep a torch in the shop, we don't use it very often--more frequently for heating something rather than cutting it. And on the odd occasion where something needs to be cut with a torch I'm often guilty of grabbing it and just using whatever tip is already there. Unless the tip is grossly over or under-sized for the material being cut it doesn't get changed.
...If you have to preheat you need a bigger tip. I have cut up to 4" plate, no preheat needed, but earplugs helped...
Yup, set up properly an O/A setup is still the most practical way to cut thicker materials...
...I have to run the preheat up high to get started, and don't have the fancy 5 regulator system like the fancy machines to drop the preheat after pierce.
So I doo get more round over than I would like...
But it's the machines fault, right?
Old 05-25-2019, 02:27 PM
The only reason I preheat thick metal is I use a small Victor Jr. torch..NO not quite the proper torch to use for cutting 1" thick plate But I can cut it with the torch I have. another reason is I don't normally have a need to cut anything thicker than 3/4" and that is only once in a while mostly it's 1/4" to 1/2"
and the V, Jr. will do it quite nicely...
So I do use a larger tip I do keep my tip clean but if the regular need for cutting thick materials above 1/2" is not there then no need to have a larger torch and preheating or drilling a through hole serves the intended purpose.
But most of the cutting needs for thicket metal/materials I usually need can be done with the porta band or on the band saw or my gas powered portable chop saw, in any event, I will get it cut however I need...
So I don't see where all this went form a DIY tips and tricks video to the limp noodle contest... when preheating or drilling a through hole in thicker metal does work when your torch is inadequate in its ability you can still get the job done.
