Old 05-24-2019, 09:19 AM
Oh, shoot Jack. I was going to say about as long as it takes to hit the
"Buy It Now" eBay button...
I’m just a poor platypus, all I can afford is a couple of clamps, tape rule, straight edge, some string and a scrap piece of soap stone.
Along with an engineering handbook
Old 05-24-2019, 09:22 AM
About a hour........that includes set up and clean up time
My friend has a burny3 and it has the same "library parts"
I watched him one day make the above listed.
Standing at the machine, he simply selected "part #5".
Up popped a menu asking first for the O.D. and he simply keyed in "24.00"
then was the hole size, "1.00", then number of holes "8".
The B.C. he keyed in "22.00"
It asked "center hole" and he set "00.00" or "no".
Push button and it was burned out complete.
Need another ?
Move torch to another area of the plate and hit "0,0"
and there's the second one.
The whole process was just as I typed it, maybe 10 minutes including
putting the plate on the table, and grinding off some minimal slag.
Old 05-24-2019, 09:26 AM
That buy it now button is plucking me for sure
Old 05-24-2019, 09:31 AM
Need another ?
I'm just not sure which to buy... for now even if only straight line type could be better till I could afford something much better but I still want one with the x,y, and z-axis
so being undecided is the only thing holding me from the buy it now... and having to et a new plasma machine with the right requirements.
Old 05-24-2019, 11:00 AM
THEY ARE HAVING A SALE ! ! !
https://www.koike.com/documents/pnc1...15off_rev3.pdf
15% OFF.....
Old 05-24-2019, 02:08 PM
No, Not that I know of I wonder if it is worth the money??
If someone can say I am willing to make the investment due to floor space and being portable might just make it more affordable for myself but what are it's max and min limitations what is your opinion of t usefulness
floor space? just may not be that easy, I assume you need at least 2 inches of clearance for burn through it maybe one thing if you have to cut one large part but if you need a lot of smaller parts you just may need to make a special table just to keep it above the ground surface, i don't see a plywood table working very well .......
Old 05-24-2019, 02:23 PM
Your not seeing it...he can pile junk all around the thing when not being used.....
Old 05-24-2019, 08:20 PM
I was looking at a similar concept from Langmuir Systems for about $1500. It only cuts 2'×2'. Makes me nervous buying a large table when these little ones are getting so cheap.
Old 05-25-2019, 10:20 AM
15% OFF.....
DD,
At least for at least, you and I, we could pick it up directly from the factory....
Old 05-25-2019, 01:57 PM
DD,
The sale is only for the PNC-12 EXTREME and it is 12,500 and some change for it..... I've done been on the phone with them... so it's out of the question.
