Old 05-19-2019, 04:18 PM
gimpyrobb's Avatar
Default Ingersoll Rand 231 half inch impact
So I got this impact gun through some trading. It works well and has good power for its size, but the C clilp on the snout is toast and doesn't hold the sockets on anymore. The nose is in rough shape in general actually. Not sure if a C clip swap is possible. Has anyone ever done this type of maintenance? If I have to swap in a new snout, I can accept that, but I'd like to try to swap it out first.
Anyone have any guidance?
Old 05-19-2019, 05:11 PM
Got a couple of pic of the snout to see what you mean by a rough shape like in missing the nose that holds the ring clip ??
Old 05-19-2019, 05:31 PM
Scotts Scotts is offline
Yep,
go to the IR website and look at the kit to repair all this. The c clip and backer ring may be available from Mcmaster in individual pieces.
I am awaiting a gun with a pin style retainer and then I will see about rebuilding the front end of the clip style retainer.
Old 05-19-2019, 06:57 PM
Camaro Zach's Avatar
Just Clips brand pn: JC500 are what I have had good luck with. Made in USA to boot.
Buggy
Old 05-20-2019, 03:18 PM
gimpyrobb's Avatar
Looking at it, its toast. I will probably just use it as is. A new anvil is only about $40 but I am cheap. I may just make an adapter for it.
Old 05-20-2019, 03:45 PM
Thanks Zach,
I found them on amazon and ordered.
Old 05-20-2019, 05:28 PM
well, Rob. If you're that cheap ...I would drill and pin style the thing and be done with it... Or at least till that wears out or the impact goes south totally...
Just poking pun on the being cheap Rob hell I'm the same way with things like that... no need to make a chap working tool cost more than it has to right...
That's my floskaloscopeeee
The other thing you could do is pull the hammer out set it up in the mill cut it down to a 3/8 drive cut in a new nose for the ring clip-3/8 clip and you would have one hell of a torquey 3/8 impact
DangIt... I just gave my self a heck of an Ideer... I have a nice slimline compact Impact "no-name brand" but it ain't worth a hoot's toot as a 1/2" drive impact, I think ill do just that as it will make a good 3/8 drive for sure... save me from having to always be searching for my 1/2-3/8 adapter for it...
Old 05-20-2019, 09:03 PM
let us know how the milling cutter liked that steel
Cutting it down is a good idea but I would use a grinder to trim the anvil.
I see a few of them at yard sales often way over priced but sometimes priced right for a parts gun . I have never seen a lot of wear on the hammers usually it is the air motor that is toast from no oil abuse running on wet air from a service truck mounted compressor.
Old 05-20-2019, 11:31 PM
Terry, You're prolly right about the mill a cutter... "I was having a brain fart moment". But I can do it with my surface grinder no problem... But I still think it will be a good idea for this slimline impact to turn it into a 3/8 drive...
If, I screw it up. well, no big deal... It was less than a hundred twenty bucks not that I'd buy another new one anyway.... because it is as useless as tits on a boar hog and piss ants for required half inch work.
So I'm glad you brought that up Because I would hate for another newbie like
me to tear up and ruin a good end mill for one of my "A typical brain farts ideas"...
Old 05-21-2019, 01:07 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
I used to work with a guy who was always bragging about how cheap he was. His wife said that he could squeeze the ink out of a dollar bill. I told him, "You may have written the book about being cheap but, I picked it up at a yard sale for 50 cents."
Dave
