Old 10-10-2018, 06:18 PM
Lowe.Buuck Lowe.Buuck is offline
Default Lubricants Safe for "Yellow Metals"
I have an old snowblower that I'm putting back in service. I became aware that there are lubricants that are not compatible with "yellow metals" and will accelerate wear.
I have some "00" lube that is not marked as safe for yellow metals. I sent a couple messages to the company and got no response.
Further online research led me to Machinery Lubrication - The Effects of EP Additives on Gearboxes.
I found a datasheet on the "00" grease I have and it lists that it tested Copper Corrosion per ASTM D-4048 and passed.
Is Passing ASTM D-4048 enough to make it safe to use in a gearbox with a bronze gear?
If not, what standard must be passed for a lubricant to be labeled as "Safe for Yellow Metals"?
Old 10-10-2018, 06:28 PM
I don't remember the particulars but if you look up discussions on the harbor freight bandsaws the first thing everybody says is to change the oil in the gearbox, and they listed several types that were safe for yellow metals and worm gears.
Old 10-10-2018, 07:48 PM
Here is one relevant link.
It is post#3 to this old thread.
Old 10-11-2018, 09:32 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
Does ye're oil have GL numbers?
GL4 is what's normally used here in old gearboxes, but only things pre 1970 or so, anything newer is normally fine with GL5
Old 10-11-2018, 08:41 PM
Matt - I will take a look at that discussion.
Cutter - I took a quick read through that article, I'll have to read it all the way through.
JohnBoy - I don't know what the original lube is, or was. This is an old Simplicity blower. I'm guessing from the late 60's or 70's. The auger gearbox has been replaced and a decal added noting the upgrade. I don't know why it was changed. I have read that many GL5 rated lubes are not safe unless it is marked as safe. I just want to make sure the lube I use is safe for this gearbox.
There are a lot of discussions online about this issue. No definitive answers other than to select a lube marked as "Safe for Yellow Metals". I'm trying to determine what test is used to meet this requirement.
Old 10-12-2018, 07:25 PM
No and No.
GL 4 and 5 are for automotive gear boxes and do not have brass or bronze components.
Old 10-12-2018, 09:10 PM
Matt G. Matt G. is offline
I went through this trying to find a suitable lube for the gearbox on my old delta 14" bandsaw. I settled on a GL-3 140w gear oil. Hopefully that is ok for my application. If I learned one thing, there is a lot of BS and misinformation floating around on the 'net about what each GL spec is and isn't safe for.
Old 10-13-2018, 09:51 AM
GL-3 is obsolete.
Here is a good discussion of automotive gear oils and the effect of sulfur on
yellow metals.
https://www.widman.biz/uploads/Transaxle_oil.pdf
I had a customer and high end grease manufacturer in our labs this week
for training, part of our discussion landed on ASTM D130 test method. it is
used for determining copper corrosion by the discoloration of the copper.
Many chemist have been for years trying to get weight loss (and gain) on
the copper test specimen to be included as part of the results. So far no
movement as it would create a lot of questions on what it means.
But a 1A for 1B result which for decades has been assumed to me no copper
corrosion, is not really true, you can get erosion of the surface with a net
lost in copper but the chemistry in use is still giving a 1A 1B result.
GL-X specification are for automotive gear oils.
You need an industrial gear oil free of sulfur and phosphorus to prolong your
gears in your industrial equipment.
Cutter linked to the thread with my recommendations, they have not
changed in 10 years.
Old 10-13-2018, 10:22 AM
What viscosity grade does the manual recommend?
File Type: pdf SHC 600 Series Gear Oils Circualting Oils Mobil.pdf (1.22 MB, 164 views)
Old 10-13-2018, 06:49 PM
JohnBoy's Avatar
No and No.
Rover, and some other British auto and motorcycle manufacturers, did use brass and bronze bushes and baulk rings back in the day.
