Old 09-27-2018, 11:01 AM
Default Oxyfuel cutting what ?
For WW2:
ID:	147168   Click image for larger version
ID:	147169   Click image for larger version
ID:	147170   Click image for larger version
ID:	147171   Click image for larger version
Old 09-27-2018, 05:15 PM
fish sticks
Old 09-27-2018, 05:29 PM
Uhhh read a wee bit more closely...."Gun Parts"....ooh, watch out,
they will be banning our torches soon.
Which gun were they making ? upper left of page 3 says "9mm Browning"
Same area says "oxygen 120-140 psi, acetylene at 13 psi"
That tells me they are near the upper limits.
Old 09-28-2018, 08:19 AM
alchemist's Avatar
Doesn't acetylene explode at 14psi?
Old 09-28-2018, 10:10 AM
No the danger zone starts at 15 PSI
Old 09-28-2018, 02:19 PM
They are Canadians.....
Old 09-28-2018, 04:11 PM
We don't need no steenkin' torches to whittle out guns.
Old 09-28-2018, 06:41 PM
The linked article said the person used a milling machine.
My OP was showing that a torch guided by a CAM can do very good
work, negating the need to much of the normal milling work.
Old 09-28-2018, 07:03 PM
camdigger's Avatar
Roving Reporter
Definitely NOT CAM. CAM stands for Computer Aided Manufacturing. WWII pre dates the computer by 2 decades.
Besides, Page 2 of the article clearly says "tracing head"
My question is how did they manage to get the tracer stylus to follow the pattern. My own tracer suffers from lack of adhesion between tracer stylus and pattern.....
Old 09-28-2018, 07:40 PM
It does ?
I dunno, the airco book I have that showed this machine calls the metal template that the magnetized roller runs against as a CAM.
You know, like the one in your car engine....
FWIW I have posted before, an old article showing a burning machine
run with paper tape, pre WW2.
