The guy that said money can't buy happiness never bought a tank of fuel for a turbo diesel............. |
For installation I'd use a wrench, I doubt fingers would get it tight enough.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
I think it takes a keeper to keep from turning..
Don't pick a fight with an old man. If he is too old to fight, he'll just kill you... John Steinbeck "If we ever forget that we're one nation under God, then we will be a nation gone under". ~Ronald Reagan We should have picked our own cotton... I love my women hot and my beer ice cold.. |
With that type of lock nut you tighten to required torque spec and then use a punch to fold over the part where the notch is. Makes a very positive locking mechanism. You can, in some cases, use a screwdriver to "spread" the notched section instead...
I have seen those with spring clips before, is there a machined spot on the stud?
Sent from my [device_name] using ShopFloorTalk mobile app
Hobart Titian 8000 210mp Square wave 200 Everlast 160stl Powerkraft 300 2 Loose Screws Fabrication Owner |
Slit locknut. Looks like some have the thinner part somewhat pinched. See pic for the way they grip opposite sides of the bolt thread.
http://www.s-h-w.net/e/locknut.html
USMCPOP |
When I was in 5th grade at a "progressive" school, I'd ask the teacher how a word was spelled. She'd tell me to look it up in the dictionary. How in the hell can I look it up if I don't know how to spell it? Well, I learned how to do it and learned a whole lot of off-color stuff as well. ![]() But, hey, slit nuts is an interesting concept. Of course the best way to lock nuts and bolts together is rust. It will outlast most anything it holds together (these days). Look up a formula for "rust cement". Better than Loctite red.
USMCPOP Last edited by USMCPOP; 09-09-2018 at 01:55 AM. |
Back in the bad old days, before locktite, if we wanted a threaded fastener to stay fastened, we added a drop of tincture methylate or iodine to the threads before assembly.
If disassembly became necessary, a blue point wrench was required. Occasionally, an impact wrench to break it, and then a drill out and re tap. Never had one come loose or back off. RED the ancient
A 160 MPH drive, down a 2 lane blacktop, all by yourself, is NOT anti-social behaviour... I drag race because football, baseball, and golf only need ONE ball. Paul. What I really need to know is, WHEN DOES THE SHOOTING START? |
