Old 05-04-2018, 10:46 AM
Default Bushings and Pin
Had one of those paying jobs yesterday. I do not take too many paying jobs. This was for a oil field friend. Something for his tractor. Wanted a piece of 2" schedule 80 bored and turned for bushings. Also wanted a round bar turned to to fit inside of the pipe. He supplied all the material. I used to newly made boring bar. Worked fine.
ID:	144862   Click image for larger version
ID:	144863   Click image for larger version
ID:	144864   Click image for larger version
ID:	144865   Click image for larger version
Old 05-04-2018, 11:14 AM
Looks good, milo. I like those kind of straight forward jobs. I recently did a part for a wine bottle uncorker and it was a 3 setup job on the mill. Wish I had taken some pics.
But somehow this jumped out of Machining and landed here
Old 05-04-2018, 11:17 AM
Nice job Chris. Looks like your lathe is working good.
Old 05-04-2018, 12:13 PM
Looks good Chris! Did everything run fairly true from end to end for you?
If you cut the back end of the bit on the boring bar parallel to the spindle, it should give you more clearance, and let you do smaller diameter bores.
Old 05-04-2018, 02:09 PM
Was that really only schedule 80 ? It looked thick enough to be schedule 160 .
...lew..
Old 05-04-2018, 02:11 PM
I used a live center and snuck up on the OD to eliminate flex, as well as some emery.
Old 05-04-2018, 04:59 PM
Looks good, however, the geometry of the cutting tool looks
like it would deflect the bar allot.
How did it cut ?
Any chatter ?
Old 05-04-2018, 05:29 PM
How did it cut ?
Any chatter ?
No chatter. Took light cuts since it was hanging out quite far. Took a wood dowel and bans sawed a slot and used emery on the cordless drill to get a decent finish inside.
Old 05-04-2018, 05:31 PM
How did it cut ?
Any chatter ?
No chatter. Took light cuts since it was hanging out quite far. Took a wood dowel and bans sawed a slot and used emery on the cordless drill to get a decent finish inside. Too long a boring bar for a AXA tool post. Had to give it an extra crank on the top nut.
Old 05-04-2018, 05:41 PM
When I look at a tool, I figure that "lead angle" should be just about square.
Deflecting a thin bar is the big thing, and the square tool (and minimal
radius) works best to minimize deflection and chatter.
