Old 04-19-2018, 06:21 PM
Scratch Scratch is offline
Default weld jig
Finally got some time to weld one of these suckers up. I know there are few different designs out there, but I decided on this one as I think it will be the most useful for me.
I didn't want the holes in it like some, since I figure I'd be clamping it to the table anyways with a C-clamp or vice grip. I did want to be able to fit a vice grip in there... hence the slots.
It's 4"x12"x12", and the center "web" is in the center of the jig, not flush on the flat edge like some.
ID:	144550   Click image for larger version
ID:	144551   Click image for larger version
Old 04-19-2018, 06:52 PM
digr digr is online now
That will come in handy
Old 04-19-2018, 07:55 PM
J.Ramsey J.Ramsey is offline
I've seen those advertised but kinda wondered how Square they'd be when assembled.
Old 04-19-2018, 08:04 PM
Would be easy enough to weld up and then take a skim cut to square it up on a mill if you needed to be certain.
Old 04-19-2018, 09:18 PM
I really only need it to be square in the one orientation I have pictured, but it was pretty easy to get squared in all directions. I had a large thick I-Beam that I clamped to my table and got as close to perfect as I could, then used that for squaring this up. It went pretty easy and I got it nearly perfect. I only did tack welds to keep the warping down.
Old 04-19-2018, 10:45 PM
Nice work. I made some crude ones out of angle iron years ago. I keep them around because hey they come in handy.
Old 04-19-2018, 11:50 PM
Nice........I just picked up a welding vise but it just isn't always what a job would need....... Ill have to make me some weld jigs later for this next job ill be doing.... might borrow your design there if ya don't mind...
it looks user friendly and very workable
Old 04-20-2018, 04:23 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
nice job.
I have a need for something similar but am kind of in a bit of a chicken and egg situation for making them.
warping on welding would be my concern too.
Old 04-20-2018, 06:12 AM
JohnBoy.....
If you use some 3/8" or better some 1/2" flat bar you might not need to worry bout getting to warp space.....9
I'll prolly use some 4-1/2" x 3/8'' flat I have laying around and 1/4" plate for center....That would give me 2" clamping edges either side.... I believe that should work...
Old 04-20-2018, 06:22 AM
So you used 4" wide flat strap/bar and it's 12" height configuration what was the gauge thickness of the metal and webbing ??
if ya don't mind tellin an old fella
