Old 04-17-2018, 10:22 AM
Scratch Scratch is online now
The spiral is for compound bends or scrolls, I think. For bending scrolls up to 18" wide, I have the instructions saved, because the only way I know other than your spiral is to create a spiral with bolts on a large plate, and use the math to calculate it out.
I'm still trying to wrap my head around needing a spiral layout for making scrolls.... If you have those instructions, I'd love to see them?
Old 04-17-2018, 12:31 PM
Diacro benders are probably the most versatile bending tool you're going to find. We have a No. 3 which has served us well for years. They publish a manual titled "The Art Of Bending" which has a lot of very useful info. It's specific to their machines but in a lot of cases the "principles" of bending will be the same whatever you're bending with. Worth a look, for sure. Here's a link...
Art-Of-Bending
And instead of drill bits why not use dowel pins instead? They're made of alloy steel, heat-treated and ground .0002" oversize--should be just about a perfect fit in a 1/2" drilled hole. KBC has 1/2" x 2" priced at $1.88 CDN so they're a lot cheaper than drill bits and there'd be no putzing around with cutting or anything. If you want longer they make them up to 4" long...
Old 04-17-2018, 06:22 PM
Art-Of-Bending
Hadn't thought of dowel pins, thanks for the suggestion... I'll probably go with those instead!
Old 06-04-2018, 04:35 PM
those pin benders are very handy..
As to scrolls there is a whole mathematical formula (Ironman knows it) which basically states that a box, withing a box within a box halfed each time is the correct formula..
A scroll for all intensive purposes should look like it's never getting bigger all of a sudden and with no flat spots..
Something about pleasing to the eye.. When I used to make scrolls I never new about the formula.. but I did understand how it is supposed to look to the eye..
Of course there is some variation based on size and such but for any given object bent in a circular way, there is a look that presents as smooth..
_________________
Jennifer
My google+ page
DoALL 36"
Old 06-05-2018, 09:59 AM
Jen, do you mean a nautilus scroll?
Name:	Nautilus scroll Fibonacci sequence.JPG
Old 06-05-2018, 12:14 PM
Our friend, Mr. Fibonacci,
https://en.wikipedia.org/wiki/Fibonacci_number
Old 06-05-2018, 01:52 PM
Yeah, I get the whole Fibonacci/Nautilus thing... But I'm still having a hard time figuring out how the spiral layout of holes, (like they are in the first pic in this thread) helps to make a scroll.
I can't find anyone on the web using that layout to make scrolls.
Old 06-06-2018, 04:13 AM
JBFab JBFab is offline
I made a scroll bender for the Hossfeld knockoff I made many years ago. I'll see if I still have the CAD file.
I used the golden ratio to lay mine out (which is essentially the same as the Fibonacci sequence shown above). After doing the layout, I added some shape to it, and cut the 2 pieces out of 1" plate with a torch. I hinged the two pieces with a #80H? chain link. I don't usually end up using the second piece.
Depending on what time I get home from Madtown, I'll add some pictures tonight.
Sent from my [device_name] using ShopFloorTalk mobile app
