Old 02-02-2015, 07:28 AM
Originally Posted by Scrapper Greg View Post
Not a bad deal at all!!! There are 2 things I would change on your setup. First is in the second to last pic. On your clamp system (which looks great) it appears to only be held to the main structure by 1 bolt. The second appears to not be connected to the structure. And the second, on the top of the vertical pieces that are in said clamps. I would do a square/ rectangle adjustable arm on the top of it. It would allow a bit more adjustment.
I don't get what you are suggesting in your first comment Greg, there are two 1/2" screws that can be clearly seen securing the clamp assembly to the dolly frame.
I don't understand your second suggestion. Would it improve vertical or horizontal adjustment? The screw hole pitch is five inches.
The only issue I have encountered is the thread rod interference with the dolly frame when it is positioned over it. In this case I am limited on how low I can position the saddle.
Old 02-02-2015, 09:50 AM
Scrapper Greg's Avatar
After looking at it again, I might have been a little off on my view on the first comment. Is the round tube adjuster welded to the angle? If so ignore the first comment. As far as the second, What I was thinking was where you have the square stock welded to the the top of the round vertical adjuster stock, weld in a piece of square tube horizontally to the top of the round and make an adjuster just like the round one so the your square stock can slide in and out too.
MAGA
Old 02-09-2015, 11:23 PM
[QUOTE=Scrapper Greg;619638 What I was thinking was where you have the square stock welded to the the top of the round vertical adjuster stock, weld in a piece of square tube horizontally to the top of the round and make an adjuster just like the round one so the your square stock can slide in and out too.[/QUOTE]
I have now realized that this dolly attachment could benefit from the modification you are suggesting. I have however come up with a different modification that will offer some of the advantage of yours with much less effort.
My plan is to lengthen the angle by three inches on the end opposite the tube column. I will then slot the two round holes in the angle making them .5" X 3". This will give three inches of fore/aft adjustment which I think will greatly simplify the setup.
Old 02-09-2015, 11:26 PM
I also made a four foot model. This will be used for truck cabs and beds.
I used one standard 8 foot dolly that was damaged and shortened it.
Old 02-09-2015, 11:30 PM
View of short dolly.
Old 02-09-2015, 11:38 PM
View of fishplate joint before welding.
Old 02-09-2015, 11:42 PM
Using another fullsize dolly as a fixture.
Old 02-09-2015, 11:45 PM
Welded fishplate joint.
Old 02-09-2015, 11:56 PM
Small dolly supporting a truck cab.
Old 02-10-2015, 09:15 AM
moose's Avatar
moose moose is offline
Nice modular concept. Are these intended for storage/blasting/painting only? If you are going to weld/grind/pound do you think that the 3/4 rod will be strong enough? Do you plan to add any type of caster lock to prevent movement?
moose
Southeast Michigan
https://www.facebook.com/Metalcraftbymoose
