![]() The plan here is to remove all pieces that are attached to the main frame and replace with attachments of my own design. I have already made most of the pieces in anticipation of a build I planed for this winter. Below is a picture of what I am starting with.
Shit began hitting the fan in the 1950's https://m.youtube.com/watch?v=nRnNDkHb0MU A technologically advanced society would teach their children how to start a fire by rubbing two sticks together before teaching them how to use a lighter. Aren't energy consumption and computers supposed to make life less stressful? If you are not having fun then you are doing it wrong. |
I drilled and tapped 28 holes in the center of an 8' long piece of 1/2x2 HRS last nite.
I also removed all the unwanteds from the frame structure. The 1/2x2 bar will be welded to the top surface of the frame.
You got more than $45 in two casters there.
You Suck!
David David Finch Mixed Media Creations My YouTube Channel "Of all of our inventions for mass communication, pictures still speak the most universally understood language." - Walt Disney "Formal education will make you a living; Self education will make you a fortune." - Jim Rohn |
Here is the adjustable column, it is one of four. It can be secured at five inch increments along the top surface of the frame. It aso pivots on a five inch radius and can be placed on either the in or outside of the dolly's frame rail. This arrangement offers 15 inches of coverage on each side of the dolly. This should accommodate any body or frame I wish to put on it.
The column is also adjustable in height with a travel of 13 inches. The 3/4" thread rod is 12" long. This gives a 38 inch maximum height of the saddle.
View of column clamp and mounting.
I wanted a dolly that is not obstructive. This is particularly important when welding, sandblasting and painting.
Not a bad deal at all!!! There are 2 things I would change on your setup. First is in the second to last pic. On your clamp system (which looks great) it appears to only be held to the main structure by 1 bolt. The second appears to not be connected to the structure. And the second, on the top of the vertical pieces that are in said clamps. I would do a square/ rectangle adjustable arm on the top of it. It would allow a bit more adjustment.
MAGA ![]() |
Saddle option no. 1
Saddle option no.2. This is mainly for bodies which often have holes which would recieve such a cone. Unlike the straddle type saddle shown above, the cone is threaded to engage the 3/4-10 rod.
