Old 09-19-2014, 12:45 PM
Originally Posted by USMCPOP View Post
I like the Amish CAD drawing.
I think he subbed out the engineering drawing to the local kindergarden... Just kiddin' Joey! It would have been a little bit more clear if you also drew the cab of TSF...
Old 09-19-2014, 09:58 PM
King of Obsolete's Avatar
Published Author
here is the whole picture that i drew by myself with ut help from my mom, lol.
i also did a road trip today to unload a semi on to a barge. great fun on something that floats, moves and leans when you are a afraid of water, lol.
thansk
KoO
Published Author
Name:	Screaming Ford weight box tow truck full.jpg
ID:	118459   Click image for larger version
Name:	Barge loading sept 19 2014 009.jpg
ID:	118464   Click image for larger version
Name:	Barge loading sept 19 2014 014.jpg
ID:	118465   Click image for larger version
Name:	Barge loading sept 19 2014 015.jpg
ID:	118466   Click image for larger version
Name:	Barge loading sept 19 2014 016.jpg
King of Obsolete
Cat Train Tours
Old 09-20-2014, 10:12 PM
Published Author
i was able to make the hinge pieces for the back of the Screaming Ford in my little shop because of the rain. first i got a little wet cutting out the pieces and did a little grinding to get them ready for assembly. next i tack welded the pieces to the work bench and then welded the jig steel in to place. with the jig steel in place i can now weld the whole unit to the back of the Screaming Ford without worrying about a bunch of measurments. less thought required at my age, lol.
next i found some 2.25 shaft with 3" bushing to make the cradle thing pivot. one thing i hate the most is grinding so i free hand cut the holes for the shaft so i didn't have to do a bunch of grinding. i needed a tight holes and that is what i got. this saved on a lot of welding being tight. by 8pm at night it was dark and i used a flashlite to finish welding the pivot to the cradle thing.
thansk
KoO
Published Author.
Name:	Screaming Ford tow truck assembly sept 20 2014 001.jpg
ID:	118492   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 20 2014 003.jpg
ID:	118493   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 20 2014 005.jpg
ID:	118494   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 20 2014 006.jpg
ID:	118495   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 20 2014 008.jpg
King of Obsolete
Cat Train Tours
Old 09-21-2014, 10:02 AM
Nice cut on the pivot pin hole.
Woodrow Wilson
Old 09-21-2014, 09:07 PM
DeepSeaDynamo's Avatar
DeepSeaDynamo DeepSeaDynamo is offline
That is really impressive use of a torch. other then that I'm speechless
Old 09-21-2014, 09:39 PM
Published Author
thansk guys, i learned how to torch when i used to scrap metal for a living. back in the day i could cut straighter and faster with a 72" torch then a short torch. i figured i save a lot of time grinding by cutting it correct the first time.
it took about an hour to free hand cut the 2 pipe for the "A" frame on the cradle. i weld the pieces to the rafter trailer then worked away at getting a nice fit on the first pipe then copied it to the second pipe. another hour was spent welding up the "A" frame then joining it to the cradle. finished up tonight with the "A" frame and cradle mounted on the Screaming Ford. will slip the weight box on in the morning then i can figure out where to mount the pulley on a stick.
thansk
KoO
Published Author
Name:	Screaming Ford tow truck assembly sept 21 2014 001.jpg
ID:	118520   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 21 2014 002.jpg
ID:	118521   Click image for larger version
Name:	Screaming Ford tow truck assembly sept 21 2014 004.jpg
King of Obsolete
Cat Train Tours
Old 09-21-2014, 09:55 PM
Did you use the 72" torch for that piece?
Old 09-21-2014, 10:00 PM
So there's pretty much a new big rig tow truck in the Great White North. Time to go show all those "FANCY" trucks with their complicated computers why mechanical injection can tow them out of the bush.
Old 09-21-2014, 10:12 PM
Published Author
i used an 18" torch and free hand to cut the holes for the pins on the "A" frame and cradle. once you start the hole you don't stop and just follow through. that way you get a nice smooth hole.
i do a fair amount of winter road towing because of the computers shutting the trucks off. but once we get close to town we have to unload the high top sleeper trucks because the bunk is too high for the hydro wires. now i can haul these trucks no problem plus any 3 ton cargo van trucks too. over the years i keep bettering myself by add more things or equipment to my collection.
thansk
KoO
Published Author
King of Obsolete
Cat Train Tours
Old 09-21-2014, 10:27 PM
thansk
KoO
Published Author
I figured, I was just being a smart ass.
