Old 09-08-2014, 06:48 AM
Not quite That 4000-4500 wats is at 240 volts that welder is running on 1/2
that (120 v) as it is only using one side of the generator.
Originally Posted by Graybeard62 View Post
The genset has both 110v and 220v ports. It ran the a/c on my travel trailer,
runs my service truck including 110v compresser, let's see, what else?
What Terry says applies then you only have half the power available.
No I assume very little. All the off the shelf home owner units over 1500 watts
come with a 120/240 receptacle.
I have a 3.5kW unit that is 115V only...
http://www.shopfloortalk.com/forums/...ight=Generator
Old 09-08-2014, 08:21 AM
I can run 1/8 rod with my little 5 hp unit.....but the I made it myself
Old 09-08-2014, 08:35 AM
Is that a relativley new store bought unit ..... or one you built ?
Most the newer factory homeowner units *can* be set up as 120 only.
To do this you need to get down to the basic winding level and discard all the built in features. You may also need a transformer to provide 240 to the built in regulator.
This is not a trivial mod and will probably cost as much or more than the original purchase price for the unit in question.
Old 09-08-2014, 12:33 PM
chumly2071's Avatar
Urban Gunfighter
I usually use a 10kw generator when I weld on generator power, but then I am not considered normal...
http://www.shopfloortalk.com/forums/...1&d=1355379421
Old 10-04-2014, 10:35 PM
Cedarcreek Cedarcreek is offline
I have run my Lincoln Weld-pak 155 with my 5000w Honda generator quite a bit before I got a better portable welder. I was pushing the upper limits of the Lincoln, using higher wire feed speeds and voltage settings than Lincoln recommended for .035 flux core because of the thickness of the material I was welding.
If you don't have time to do it right,
when will you have time to do it over?
Cowboy Logic: "Experience is what you have when everything else is gone."
“The inherent vice of capitalism is the unequal sharing of blessings. The inherent virtue of socialism is the equal sharing of miseries.” ~ Winston Churchill ~
Old 10-19-2014, 11:10 PM
Scott V's Avatar
Scott V Scott V is offline
I had great luck using a cheap china generator for powering a small mig. 3500-4500 peak. Basically something like Shade has, but mine has 120/240 volts..(7 hp) The catch is the welders a inverter, and has PFC. Runs like it plugged into the wall.(Tweco 141i) I have a MQ 6000 (11 Horsepower) and it's much more suited for the smaller 120 volt standard mig. It's all hit and miss. It's the combo between machines that matters. I can run my 240 volt Esab Caddy-mig 200 on the China generator almost to full voltage and wire-feed.. Runs prefect, but right at the very top. Use my 186 AC/Dc Thermal-arc at 200 amps tig on the MQ perfect. Esab 2200i AC/DC will only go to 165 amps output on the MQ. lot of generators have full Out put on 120 volts Both the MQ, and the China one has Full output settings for 120 volt operation..
http://www.generatorjoe.net/html/generatorops.html
Name:	genny fleet.jpg
Old 10-20-2014, 10:30 AM
rustythe4x4's Avatar
I have owned factory built units of up to 6.5 kw that were 120volt only. They often fall under the RV category and are cheaper to purchase for the RV'er that wants to run his air conditioning and microwave at the same time and not pop the breaker on the generator. ( I see them in RV shops all the time)
Another problem with trying to run the welder off the genny is the sinewave pattern from the genny may be so distorted it just wont run the welder. I have had this happen to myself, and thought it was the diodes again (smaller 120V welder) but when I plugged it in at the shop, it worked flawlessly. The genny being used was a 5kw unit, and capable of running higher loads - and would run lights or heaters with no problems, but a grinder would stall under load.
I checked the output and it was a jagged mess that still gave me about 115vrms, but spiked somewhere around 200vp and had a huge ramp sawtooth pattern that would not run anything with a transformer or inductive motor.
I know that isn't much help, but try to find a genny that is true sine wave. It may help.
Living the country life
Mathew 10:36
-Ironman quoting the Bible
