Old 08-04-2014, 04:58 PM
Okay, I bid it with heavy wall tube, and specified 4" and 6" radii. If it pans out I will keep you posted.
Old 08-04-2014, 05:08 PM
Get solid bar hot enough and it shouldn't be a problem:
Extrusion operations typically take place with billet heated to temperatures in excess of 700°F (375°C), and — depending upon the alloy being extruded — as high as 930°F (500°C).
Old 08-04-2014, 05:46 PM
Keep us posted even if it doesn't pan out.
What wall thickness? What bender do you have? In 6063 the 6" rad. will be no problem--the 4", with a good bender--like the Baileigh--and proper dies should be OK. Some of the cheaper benders not so much...
Old 08-04-2014, 06:31 PM
clive's Avatar
clive clive is offline
Originally Posted by Harvuskong View Post
Many years ago in the 1960s. I read a tech article in Hot Rod Mag about annealing aluminum for sheet metal work. I remembered it about oh 40 years later and tried it and it worked on irrigation pipe.
First I set the oxy/act torch to running really black smoke.
Then I blackened the area to be annealed with the black smoke.
Then I readjusted the torch to the clean neutral flame.
Then I burned off the black smoke covering with the neutral flame.
After I let it cool down, it was soft enough to bend it to wrap it around one side of the cracked aluminum ladder leg that needed to be reinforced and pop riveted the patch to the ladder leg.
However clive's idea maybe better if appearance is a factor. Or the material is thicker than irrigation pipe.
I've heard of the blackening method too, never tried it though.
It's So Easy
Old 02-05-2015, 10:18 PM
I needed to drag up an old thread, as it looks like the job is going to go. As I recall, I built in enough money for a hydraulic bender. I have the American Bender version of the Hossfeld No 2, but no hydraulics. Got the plans, but not the time.
So now I need to figure out if I can get it changed to tube, or if I can bend the solid bar.
Old 02-05-2015, 11:11 PM
I know this isn't how you work, but could you sub the bending to Chukar? If it's only a small part of the job, you may be money ahead. If not, buy a piece of 6063 T-1 tube and give it a go. I would stay away from solid bar. You'll probably tear up your bender.
It sounds like a handrail job.
Old 02-05-2015, 11:28 PM
Walker,
Last fall I had to make some 1 1/4" alum pipe handrails, and my boss wanted the ends to return 180 degrees. He ordered 1 5/8" solid round stock and I bent it in our hossfield bender around a piece of 3 1/2" pipe as a die. I heated the alum up using method mentioned by Harvuskong,
only I bent it while still warm. One thing I think putting the black soot on it, was the alum was heated up enough to bend when it was hot enough to burn off clean, otherwise it can be difficult to tell temp of the alum when heating it and trying to judge the temp. I then cut it to length needed and welded it to the 1 1/4" pipe and blended in the joint. We could have bought the die from hossfield ( I think about $300) but money was tight and boss didn't want to spend any. After checking Wagner Co for pre formed elbows, we would probably only have to bend 30 elbows before the die would have paid for itself, but no go. Bending around the pipe, caused some flat spots which I was able to blend in, so was just a little more time.
If you get the proper dies, and hydraulics, you can probably bend them without heat. How ever, it might make a difference on how old the alum is. I had to bend some offset posts from alum one time, and I was using some stock that was a couple of years old, and it kept cracking on my. I was using proper size dies and bending around a 30 degree bend. I got some new fresh stock, and it bent without cracking. Only thing I could think of was the aluminum hardened slightly as it aged. (something like a good wine maybe?)
Name:	alum rail1.jpg
ID:	121988   Click image for larger version
Name:	alum rail2.jpg
ID:	121989   Click image for larger version
Name:	alum rail3.jpg
Old 02-06-2015, 01:35 AM
I routinely bend 1-1/2" x 1/8" 6063 tube 90^ with 3" radi on a good ol' exhaust pipe bender at a friend's shop. The 1-1/2 dies are like brand new as that is not a popular size for exhaust and I have sanded and filed them as necessary. I turn the pressure down to about 1/2 normal to avoid crushing the tube. A little Lube-E on the dies each time leaves a very nice bend with minimal dressing needed afterwords. Takes me less than an hour to do 40 bends. I hand my buddy a $20 bill for "rental" of the machine.
I tweak the tubes to perfect square and level in a jig when done...
TA 95 lunchbox w/tig
Old 02-06-2015, 07:37 AM
chumly2071's Avatar
Urban Gunfighter
That was my big concern, the surface damage to the tube or round bar during bending caused by using a rotary draw bender like a Hossfeld, Pro-tools, or JD2... May not be an issue, and easily solved with some light buffing/sanding/polishing.
Old 02-06-2015, 03:24 PM
Or maybe some heavy buffing/ sanding
