Old 04-06-2013, 09:44 PM
karl-nc karl-nc is offline
Default hf tube roller
bought the HF tube roller and extra 1/2" die set. need to roll 1" square x .062 and .075. measured the groove at .540". So I had the grooves turned out to 1.04. rolled some .062" wall and its sticking hard on the top roller. should the top be wider or is it "just the way it is"?
Old 04-06-2013, 09:56 PM
gimpyrobb's Avatar
Hard to say without pics. Are you washing it down with wd40 between rolls?
Old 04-07-2013, 07:29 AM
here are some pics. didn't use any wd40. as tight as it is I don't know if it would matter. I have to beat it out of the top roller
ID:	104085   Click image for larger version
ID:	104086   Click image for larger version
Old 04-07-2013, 09:37 AM
MarkBall2's Avatar
You need to flare your sides slightly & make a radius at the bottom corner of the roller.
The dies should be run dry or the top roller will slip & you won't be able to roll the tubing. I just did four 12' x 2" x .095 tubing for a couple gates & it was a job doing it manually.
Previously I had done some 1/2" square tube for barrel smoker kits & then some 3/4" for another project. Like you, I bought an extra set of 1/2" square tube rollers & widened the slots to 3/4". I found out the sides need tapered or you end up with the same thing as you show in picture 2.
Tapering the sides of the groove & making the bottom a radius will help. Wouldn't hurt to open it up a bit wider too, but that will happen when you taper the sides. Doesn't need much taper, just enough to allow the tubing to roll past without pinching it tight.
Mark
Hobart Handler 175
Chicago Electric 165A DC TIG
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Harbor Freight Tubing Roller
Craftsman 12 x 36 lathe
Papa Lion's Gate Build
Old 04-07-2013, 10:00 AM
Thanks mark. how much wider do you think would do?
Old 04-07-2013, 10:04 AM
You don't even need grooved dies to roll 1/2" and 1" tubing. have rolled miles of it with flat dies. Very little distortion in a cross section that small. So long as it rolls through okay, and you can get it out at the end, it will wear into being a littel looser over time, grease on the sides will help though.
Old 04-07-2013, 10:07 AM
MarkBall2's Avatar
If you taper the sides up to about 5 degrees on both sides, that should do it. Try it at 3 degrees first, then take another slice up to the 5 degrees taper. At 3 degrees that will give a total of 6 degree taper combined, 5 degrees per side will be a 10 degree taper combined.
I don't know how much I did, I just set the compound at 3-5 degrees from 90 degrees then shaved down to the base of the groove. I don't remember exactly what I ended up with, but I know I didn't get over 5 degrees from 90 degrees per side.
Mark
Hobart Handler 175
Oxy/Acetylene set
Hand/Power tools
Clark 4x6 Bandsaw
Old 04-07-2013, 10:08 AM
I was wondering that about not having a groove on top also
Old 04-07-2013, 05:39 PM
Portable Welder Portable Welder is offline
I have one unfortunately the dies are for round tubing and not pipe so I opened up the 1-1/2" die to roll 1-1/4" sch. 10.
I got the job done but not without drilling and pinning the die to the shaft.
I was making a curved hand rail, every time I stopped and started it left a mark on the inside radiouse of the pipe that I had to grind smooth before painting.
On the flip side it was nice to be able to take it out on the job because the side walk was not a constant radiouse so some areas were tighter than others.
Old 04-07-2013, 05:47 PM
I have drilled out the metric threads and tapped out to 3/8 16. as soon as I get my plasma table back up I am making new sides for the roller to extend out the rolls
