Old 11-20-2012, 11:47 PM
Twice the size--half the man
I have some .035 stainless spring wire, I might could bend you something up or coil some up and ship it out to you if it'd help?
Old 11-21-2012, 03:54 AM
Boogity's Avatar
Boogity Boogity is offline
Here's a quickie design that I have used in the past. There are many variations to this design to fit certain applications.
I have shown the spring steel (red) as a very thick piece of metal but in reality it is a thin tempered strip. The dimensions of the spring will change to achieve the amount of return-to-center force required.
The main shaft (blue) as I have sketched it is simply a square rod with machined ends to meet the round diameter requirements. You can also use a round rod and file/machine a "flat" section for the spring arms to rub against. The key to success on this design is to make sure there is a small amount of silicone grease on the "flats" and on the round shaft ends (unless you are using ball bearings).
For light duty applications you can use spring steel piano wire for the spring material.
I hope this helps.
Boogity
Our Republic can survive a Barack Obama, who is merely a fool. It is less likely to survive a multitude of fools such as those who made him our president.
Old 11-22-2012, 06:40 PM
Scrapper Greg's Avatar
Andy, Here's a bit of info that might help you out.
http://home.earthlink.net/~bazillion/intro.html
MAGA
Old 11-22-2012, 08:43 PM
RancherBill's Avatar
there has to be an answer
This might somewhere to start. I think you could start with a sliding barn door latch.
I googled barn sliding door latch.
ID:	98061   Click image for larger version
Name:	Stanley_Hardware_833251_Zinc_Heavy-Duty_Swing_Barn_Door_Latch_Heavy-Duty_-_Swinging_Steel_-_Each.jpg
