Old 06-23-2004, 11:35 PM
flash_burn flash_burn is offline
Default Tig Torch
Can the damaged end on the power cable for a water cooled tig torch be easily replaced(the end that screws into the 45V11 power block)? It is leaking water because of a gouge on the sealing surface. Or do I need to replace the whole cable? Thanks
Old 06-23-2004, 11:58 PM
Franz Franz is offline
Banned
A welding supplier ought to be able to provide you with a new end off the shelf.
You also might be able to fill the scratch with epoxy, like JB Weld, and dress it to shape with sandpaper after the epoxy cures.
