Old 03-07-2009, 09:22 PM
Default Fan
A friend of mine had his exhaust fan for his boiler in his garage brake and he couldn't find a replacement wheel for it and a new fan and housing was at least a week out. So I made the mistake of saying that I could probably fix it for him. four hours later I was done. The old hub that was crimped in had riped out so I had to put the fan blade in the four jaw chuck and used the old hack saw blade trick to indicate it and bore the hole out bigger then made a new hub with a shoulder cut in the fit the new bore leaving the the back (less than 1/16" thick) large enough to reach the formed hub on the blade and welded with the tig. My eyes aren't what they used to be but I made it. Now the blade runs true and is better than new. I will need a favor from him some day, things have a way of working out. This isn't much of post but maybe it will help someone some day.
ID:	43034   Click image for larger version
ID:	43035   Click image for larger version
ID:	43036   Click image for larger version
Old 03-07-2009, 09:26 PM
rickairmedic's Avatar
SFT HVAC Guru
Digr that looks good and will most likely outlive several new wheels its sad how they make things today.
Rick
Old 03-07-2009, 10:10 PM
"...the old hack saw blade trick to indicate it..."
Please explain.
Old 03-07-2009, 10:15 PM
Please explain.
I clamped a hacksaw blade under the tool post holder and bent it up so it rode on the fan blades then set up the indicator so it rode on the blade instead of getting caught in the blades when rotated.
Old 03-07-2009, 10:39 PM
1911man's Avatar
1911man 1911man is offline
Co-founder, Harbor Freight 12 Step Program
Nice job digr, as usual. I'm sure your friend appreciates your help and you are right. What goes around, comes around. BTW, I thought I was the only one who still has a weldor's finger.
The older I get the more I know and the more I know the less I understand.
"I'll keep my freedom, my guns and my money. They can keep the change."
Old 03-07-2009, 10:50 PM
Thats a handy unit. It was posted on the weldingweb site!
Old 03-08-2009, 09:21 AM
Larwyn's Avatar
Larwyn Larwyn is offline
Yep, I made two different sizes after seeing that post. The smaller of the two sees more use because of the limited size of my welding table. The other was made to the posted dimensions and works much better when there is room to use it.
Old 03-08-2009, 12:04 PM
migwelder05's Avatar
7.5 Fingers
dose anyone have any pics of the welders fingers? also whats the x looking thing used for?
Dylan
Old 03-08-2009, 02:16 PM
Here is a link to the finger. The X looking thing is what I used to use for drilling shaft before I made this, now I use it for center punching shafts.
Old 03-08-2009, 02:25 PM
I found out one thing about the finger don't have your finger under it if it slips of of you work
