Old 03-02-2009, 07:47 PM
tnfarmboy
Guest
Posts: n/a
Default Stick Weld Aluminum
Antbody ever stick welded aluminum? I know they make the rods, but I don't know anybody that haver used them. I have a jon boat that needs a little welding and I was thinking about trying it. I have ac/dc.
Old 03-02-2009, 08:25 PM
Nitesky Nitesky is offline
I tried it one night when I was on shift work. Decided to mess around when I found some rods left out.
Long story short - made a mess. Didn't know what I was doing and BOY, does aluminum disappear quicky
Gordie
"I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Old 03-02-2009, 08:34 PM
migwelder05's Avatar
7.5 Fingers
i dont think it will work good on thin stuff.
Dylan
Old 03-02-2009, 08:38 PM
boilerman's Avatar
SFT Brewmaster
don't do a john boat with stick...unless you want a bigger hole
Old 03-02-2009, 09:15 PM
tnfarmboy
Guest
Posts: n/a
That's what I was afraid of. I guess my best bet then is braze with alum rod...
Old 03-02-2009, 10:06 PM
b-footn's Avatar
b-footn b-footn is offline
Yes girls, he's single!
I've used the stick rods, and like was said, don't try it on thin stuff. I use a spool gun for aluminum work, which has been a long time ago now.
Old 03-02-2009, 10:20 PM
I have used it a lot for welding 3" pipe bungs into 3/8" wall aluminum tanks, PITA to work with, as others have said not good for not for thin stuff. Rod disappears quickly, lots of smoke and very hard to see the arc puddle, because the rod is used up quickly, very hard to get a good looking bead. Spool gun or tig for thinner materials.
Old 03-03-2009, 05:09 AM
What are the areas in particular your needing to fix and material thickness's of these areas?
Old 03-03-2009, 10:22 AM
I admit I've never done it, just tig and mig of aluminum.
but I've witnessed it, and I've seen the results.
Best description I've heard of it was from a poster (on another forum)
"like trying to shuck walnuts in the dark,.......with a logsplitter."
Old 03-03-2009, 11:12 PM
ken98k's Avatar
ken98k ken98k is offline
I used to see advertisments for aluminum welding rod that was suposed to work with a propane torch.
I don't recall the name of it but it might serve your needs if you can find it.
Edited
Here's the link
http://www.durafix.com/
