Old 06-20-2004, 05:25 PM
wolfgangwelding's Avatar
wolfgangwelding wolfgangwelding is offline
Default flux core wire from hell
Hey all want to ask about this flux core wire i got to use in my Miller 3045fc. The wire dosent seem to be a very good wire to me it dosent seem to run smooth and there is not realy a flux coating after makeing the weld. It just seems that other wire I have used in the past have been much easyer to work with to make nice beads. The wire I have is Prostar 700GS. Its number designations are E71t-GS That tells me its an all position wire. And I have made dam sure all my settings on the bobcat 225 and the 3045fc wire feeder are corect. Any help would be grate. Thx Wolfgang.
no you cant fix it with a hot pass
Old 06-20-2004, 06:24 PM
Wolf,
I don't know beans about the stuff but a Google search for Prostar 700GS gets me a couple of hits; the first one is a .pdf file that shows E71t-GS to be a flux core wire for "all position, high speed welding of coated steels".
http://www.praxair.com/praxair.nsf/d63afe71c771b0d785256519006c5ea1/fcb2fc5a83170e3585256cc40055535a/$FILE/psg%208_6-14.pdf
The second one describes it as a wire for "all position, high speed welding of galvanized and aluminized steels".
http://ecatalog.praxair.com/wcsstore...ubularWire.pdf
Maybe you're welding something other than "coated steels" or "galvanized or aluminum steels"?
Old 06-20-2004, 06:38 PM
Cutter in pounding arcs on mild steel, and some painted mild steel from which i got a good portion of porasity. I chaulked that up to not being responsible enough to remove the paint. I whent to the link you posted and it makes since. Taht wire burns prety hard core I could see how it might do well on galvenised material. Maybe I sould be a little more pationt and work with it some more, its just hard to do when I get home from work and its 97 degrees outside. Thx Cutter.
Old 06-20-2004, 07:43 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
What polarity are you running? Self-shielding should run on DCEN, shouldn't it?
Refer:
PROSTAR® 700GS is a carbon steel, flux cored electrode
for use without an external shielding gas with DCEN (straight
polarity). This electrode is intended for welding thin-gauge
coated carbon steel, ranging from 3/16" to 22 gauge.
Applications are limited to single-pass weldments.
Characteristics
PROSTAR® 700GS arc transfer is smooth and stable, with
virtually no spatter emission. This “soft” arc transfer minimizes
burn-through on thin gauge material. Availability of diameters
down to .030" makes this product a fine choice for use on
the popular 110 volt power sources.
Ory-gun Boy!
Old 06-20-2004, 08:20 PM
The bobcat 225 has tow wire settings for wire welding DCEN and DCEP I made shure I was on DCEN.
Old 06-20-2004, 09:36 PM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
Do you think it could have a moisture problem? I bought a new spool of Lincoln flux core and hated it. Pinholes, hard starts, and anything else you can think of. Turned out to be a bad spool. The new one was nothing like the first one.
BTW, how do you like your 3045? I've been thinking of getting me one for my Bobus Catus.
Don
Old 06-21-2004, 09:58 AM
DDA52 I love the 3045 my first choise was a siutcase but that was out of my price range. The 3045 is noy as rugged but I am the only one that uses it and i take good care of it so it sould last me a long time. And I think your moistuer openion has merrit.
Old 06-21-2004, 09:23 PM
DDA52's Avatar
Thanks wolfgang. I've been wondering if anyone had one. I may get one one day. Gotta get the ol' Bobus running first.
Don
Old 06-21-2004, 11:46 PM
Markopolo's Avatar
Go get yourself a spool of Lincoln Innershield NR-211-MP and let the good times roll ! If yer' not running gas, this is the stuff to use !
Jezynowka !
Old 06-22-2004, 05:21 AM
I think thats just what ill do Marko it will be good to have the comparison.
