Old 02-14-2008, 11:36 AM
Jake the Mad Russian's Avatar
Jake the Mad Russian Jake the Mad Russian is offline
Default torturing stainless
Does anyone know what happens inside SS when it's being molested in the forge-brought up to critical,and higher,several times over?Also,if it was ground down past the decarburised layer afterwards,would some non-corrosive qualities remain?I can't specify the alloy,talking about the outboard motor output shafts.Presume them to be some medium carbon deal,toughness being their main point.They rarely snap off,and are soft enough to be damaged by the vice-grip jaws in dissassembly,also the key-way likes to wobble out with time,so fairly soft.
Student:"Teacher,why has Brahm create evil in this world?" Ramakrishna:"To thicken the plot".
Old 02-14-2008, 12:25 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
no clue. Is the SS magnetic?
Old 02-14-2008, 12:29 PM
boilerman's Avatar
SFT Brewmaster
as long as you bring it up over the critical it will anneal....if not not it will work harden....it will still keep it's non-corrosive qualities because that is do to the chemistry of the metal
Old 02-14-2008, 12:55 PM
OK,thanks,that helps.
