Old 06-12-2004, 11:06 AM
SlimJim's Avatar
SlimJim SlimJim is offline
Founder: Machining Forum
Default Cutting info
I have a few different size sheets to cut and I have both a torch and plasma to use to cut them with. Both will cause the sheets to warp to some degree when I cut them. What is the best way to keep this from happening other than taken them somewhere to be sheared. Thanks guys.
Old 06-12-2004, 11:39 AM
Default Size?
What gauge are they?
Old 06-12-2004, 12:44 PM
SlimJim's Avatar
Shade, I should have said plate not sheet. I have 3/16,1/4, and 3/8. Thanks
Old 06-12-2004, 08:27 PM
john pen's Avatar
john pen john pen is offline
A plasma would warp those thickness's ? Ive only used one on alum.
Old 06-12-2004, 08:52 PM
7018's Avatar
7018 7018 is offline
Send a message via Yahoo to 7018
Default Cuts
I have only a torch it won't warp those,plazma shouldn't either!!!
Old 06-12-2004, 08:55 PM
Default Theory
First, being a Navy welder (Brainfarth, the yardbird he is, may agree) That is sheet, lololololol.
All kidding aside.
I just had a job were I was slicing up 11 ga. (0.120") steel sheet each piece was 19" on one end 20.5" at the other and 48" long, equal taper on each side. I cut them all with my plasma and had no issues with warping. The thicknesses you are cutting need quite a bit of heat to warp.
I am assuming the material is A36, hot rolled. My theory. The plate looks nice and flat before you cut them. And only after the cut the warp shows. I will guess that after you cut your pieces you are allowing the stresses in the steel from the finishing mill to manifest themselves. You are not likely doing anything wrong with the exception you purchased cheap steel. I see this phenomena quite often in I and H beams you get a nice 40' x 8" I beam cut it in a few usable lengths and start cussing because all the pieces have a twist to them and your corners are not neat clean and square.
Ah the joys of our choosen trade or hobby as it applies.
Last edited by Shade Tree Welder; 06-12-2004 at 08:58 PM. Reason: piss poor grammar (the beer factor)
Old 06-12-2004, 11:00 PM
rodburner's Avatar
rodburner rodburner is offline
Send a message via ICQ to rodburner Send a message via Yahoo to rodburner
Hmmm when i cut my silhouettes out of 3/16 I don't get any warp to them, at least i can't tell its warping.
Billy
Old 06-13-2004, 06:55 AM
WeldingWidow's Avatar
WeldingWidow WeldingWidow is offline
Talking warpin' !!!
Billy...yer eyeballs got a warp in 'em...combine that with the warp in the steel...one cancels out the other
Old 06-13-2004, 09:15 AM
SlimJim's Avatar
I am wondering now if they were that way before I cut them.
I did not check it until after started trying to weld some of it together. I did not buy it so I dont really know what kind of steel it is. It does not matter with this stuff because I am just practicing but I did not want to mess up some plate when I bought some for my table. Thanks for your help.
Old 06-14-2004, 01:05 AM
Brainfarth Brainfarth is offline
I guess it depends on how thin of a piece you want to cut off. If I think it's going to warp I'll start 1/4" or so in from the end and start my cut. Then I'll cut a foot or so and stop. Then start 1/4" or so from my last cut and so on. Then I'll let the metal cool then finish the job by cutting the 1/4" material still holding on. I still get some warping to a degree(dending on how wide the material was) I guess if your really worried about warping I guess you could shim those cuts till it cools. Otherwise you'll have to do some handywork with the torch to get whatever warpage has occured. On this stuff that buckles, I'll just clamp to down or in between something like angle iron.
-Brainfarth
ahhh yup.
