Old 07-21-2019, 05:20 PM
Default Check Engine Light
Headed out of town yesterday when the 2004 Dodge Cummins 5.9 Check engine light comes on and it goes into limp mode. 10 seconds later it goes back into normal throttle. Light stays on engine runs perfectly. Stop and turn off engine, wait 30 seconds and restart, Light still on. Drive home running fine.
Started the truck this morning, no light and runs fine. Download codes at O'Reilys Auto.
P2121 and P2122.
P2121: THROTTLE/PEDAL POS SENS/SWITCH D CIRC RANGE/PERF
P2122: THROTTLE/PEDAL POS SENS/SWITCH D CIRC LOW INPUT
It showed up 6 times on the reader. All codes were deleted.
Wondering if it is a bad connector or bad sensor.
Old 07-21-2019, 05:30 PM
I would check the plugs first, if it continues, you have a TPS issue.
A little water in the plugs can go along way.
Old 07-21-2019, 09:28 PM
Ran across this a few weeks ago on a buddy's 05 Dodge Cummins
the plug was dirty and I cleaned it seemed to go away after cleaning it...
then early this morning it came back plug was still clean and seated good sensor went bad so we replaced it and then went and picked up my bike from the dealer... and had no problems over to the dealer and back home.
So it could be just plug needs to be cleaned or the sensor is going bad.
Old 07-22-2019, 06:56 AM
flametamer's Avatar
flametamer flametamer is offline
Send a message via Yahoo to flametamer
It seems to be a know issue. Check this page for info. He seems to have it figured out.
Dt
Sero Sed Serio
Old 07-22-2019, 08:49 AM
Dt
Thanks. I have already watched that video on calibration.
Old 07-22-2019, 08:10 PM
Ordered the new TPS with a new wire harness today. $32 off Amazon. New one from Dodge is $580. Hope the Chinese one holds up.
