Old 10-15-2020, 05:35 AM
Default 10hp rotary phase converter
I would advise no less than 440 volt rated capacitors.
by all means use the highest rating caps you can get..BUT the larger voltage rated caps also use a bigger case size and can sometimes be a challenge to fit into the converter enclosure..the 440v rated caps seem to be a good tradeoff between case size and voltage rating..my shop converter has 440v rated run caps and has been going strong for an easy 25yrs.The starts usually are closer to max with a 330v rating.
Mig, Tig, Saw, Heat, Plasma, Turn, Bend, Grind and Blast
Lift, Load, Push, Compress, Generate, Illuminate + Elevate
Old 10-17-2020, 11:40 AM
OldRedFord's Avatar
Kibble King
I feel like a dummy.
I had wired my vfd up wrong and that's why it wouldn't run the mill.
I thought the yellow wire was a motor lead. It's a wire that runs from the stop/start buttons on my Kearney & Trecker
Tim
Old 10-17-2020, 04:05 PM
460 Delta's Avatar
460 Delta 460 Delta is offline
Wow, a Three Star Cutler-Hammer starter, that’s at least 50 years old, likely even more with the wrapped coil.
Perfection is the enemy of good enough.
Old 10-17-2020, 07:05 PM
Norcal Norcal is offline
50 years ago C-H used a epoxy cast coil.
Old 10-27-2020, 07:42 PM
OldRedFord's Avatar
Kibble King
I've come across some more caps I might be able to have for free if tgey will work.
Will these work for start and balance caps?
ID:	158190   Click image for larger version
ID:	158191   Click image for larger version
Tim
Old 10-27-2020, 08:08 PM
The blue one states VDC
DC only !
On AC they will likely explode.
not sure what the silver one is maybe.
Old 10-28-2020, 04:03 AM
460 Delta's Avatar
The silver ones are power factor correction caps, it lists the VARS is the tell-tale. Good news is they are rated for use 24 hours a day. As I type this I forgot what the uf said it was, but I think it said 92 and some odd uf. A couple of those is all it will take to boost the voltage on your RPC. With big ones like that, it will make it hard to fine tune it, smaller ones will be helpful to get it just so so. If you have enough, you can bank the leftovers together for the start circuit for a bomb proof cap bank.
Nice find!
Old 10-28-2020, 04:59 AM
Default 10HP phase converter
the black start caps are rated at 370VAC not 330V like I stated in the past. From the previous pics, the blue caps are DC only, useless for a converter.
  #29
Old 10-30-2020, 07:25 AM
seagiant's Avatar
seagiant seagiant is offline
Hi,
Here is my "Stone Age" RPC, it's been running a BP Mill and Horz Band Saw for 20 years.
Uses a Chi Com 7.5 HP motor with a 1/2 HP washing machine motor to get it running.
Here is a link to PM, good people and will answer ANY questions you may have no matter how deep you want to go in the build!
https://www.practicalmachinist.com/v...rters-and-vfd/
“If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace.
We ask not your counsels or arms.
Crouch down and lick the hands which feed you.
May your chains set lightly upon you, and may posterity forget that ye were our countrymen.” -Samuel Adams
  #30
Old 10-30-2020, 11:16 AM
Originally Posted by seagiant View Post
Hi,
Nice, down and dirty simple. One question, do you have any capacitors in your RPC to help keep voltages up, or whatever they are meant to do?
I think we can sometimes overthink things, but sometimes that is half the fun too.
Building a RPC is on my ‘To- Do’ list someday.
