Old 05-28-2019, 05:51 AM
Originally Posted by plott hound View Post
yupper,that would be the cats butt.damn things run about 1400 bux to rent for a weekend.
this sucker looks kinda cool https://www.farmshow.com/a_article.php?aid=15877
this sucker looks time consuming http://www.theperfecttreesaw.com/
and this one looks really dangerous https://www.youtube.com/watch?v=oqASfcTVVtU
So start building...what's the problem-o ?
Old 05-28-2019, 06:44 AM
Wolfram's Avatar
Wolfram Wolfram is offline
Originally Posted by SmokinDodge View Post
Buy a $500 pre 2000 Ford Explorer and disconnect the airbags. Have a few spares on hand and have at it. They will take out up to an 8” hickory.
"Gonna need a bigger cupholder!"
Old 05-28-2019, 09:25 AM
'from sapling size to 5-6inches in diameter"--thats gonna require horsepower and machine weight no matter how you power it or move it once cut..best approach if you have the money is to use a Fecon mulcher attachment to cut and mulch it in one pass..yeah,its gonna cost $$$$ money..I tried to do it on the cheap too but soon realized it a compromise could be made..If you do want to economize on the job then get a tracked skid steer(compact trackloader) with a top-clamp grapple rake and go at it..dig out,lift and stacks everything..culls out larger rocks and stumps too. We used a Cat 277 and got great results with it.
Mig,Tig,Saw,Heat,Plasma,Turn,Bend,Grind and Blast
Lift,Load,Push,Compress,Generate,Illuminate+Elevat e
Old 05-28-2019, 09:37 AM
Yup...what he said.
You don't want to spend the rent money ?
Recall you'll only doo it once, and then every year, use a simple tow behind
brush mower to keep it in check.
FWIW ask over at HeavyEquipmentForums.com the drum style seems to be taken over
by the disc style.
At least that's what's being said by the user over there, that use them all day.
https://www.youtube.com/watch?v=HrXzrcNQJcc
Old 05-28-2019, 09:41 AM
From the farmshow link: "The one-of-a-kind rig consists of a 14-in. dia., carbide-tipped circular blade that's belt-driven by an 8 hp Briggs & Stratton gas engine"
1. engine way too small
2. carbide tipped blades don't like to play in the dirt
3. belt drive will slip when wet (no, we wouldn't get the belt wet now would we ?)
4. Pinching a 7" tree will bend the blade, and ruin the contraption.
Old 05-29-2019, 09:39 AM
NOBLNG NOBLNG is offline
I saw this last year in the local P/A store with a "make an offer" sign on it. My first thought was WTF???
Old 05-29-2019, 10:05 AM
That whole front end is gonna be toast shortly....
Old 05-29-2019, 02:20 PM
Vernon's Avatar
Vernon Vernon is offline
Default I saw this machine years ago wow what a machine.
http://www.edinburgauction.com/lot/3...-brush-cutter/
Maybe copy some of the idea in a scaled down version.
Due to the lack of effort today Tomorrow has been canceled...................
Old 05-29-2019, 02:27 PM
Which would be as several of us have already suggested...and attachment for a skid loader (one with hi-flow)
BTW I got a good look at one of those one day, do you know what the hourly rate
is for those ?
and what do you think the greenies would do, if you hauled one in ?
Old 05-29-2019, 02:35 PM
Vernon's Avatar
is for those ?
I guy running one of these machine said he chewed up a 350 engine block didn't know it was in the weeds/brush. I was just putting out a idea like everyone else maybe use one or a little of all of them.
