  #31
Old 11-28-2016, 04:53 PM
Got carried away and added springs and a handle
ID:	136833   Click image for larger version
  #32
Old 12-02-2016, 01:00 PM
pepi's Avatar
pepi pepi is offline
Ted,
Nice work heavy duty, enjoy seeing projects with such mass. What's the welder being used, is there a sub station in the back yard?
Greg
*** KAG ***
  #33
Old 12-02-2016, 01:54 PM
Thank's No sub station, the welder 250 amp Miller running .045 dual shield with straight CO2
  #34
Old 12-02-2016, 04:06 PM
Pat's Avatar
Pat Pat is offline
Thanks for sharing. It is not often I would need a toe jack, but when you do, it would be worth its weight in gold. You have given me some incentive to try building something similar. This would be a much better approach than some of the down right scary alternatives I have come up with in the past.
If you don't mind when time permits, could you please post a photo of the clamp shown in your first set of photos (number 4 I believe ). It looks like a very handy clamp to have around a shop. I am trying to figure out if the arm that is hidden under the table is similar to a Bessy "L" clamp. Also did you purchase the clamp functioning the way it is now, or modify some Vise Grip clamps...........thanks.
  #35
Old 12-02-2016, 04:32 PM
Well it is a handy clamp but it looks like they are no longer made anywhere that I could find. Here is a pic of two of them that sold on e bay
Name:	vice gripes.jpg
  #36
Old 12-02-2016, 05:00 PM
They look like a pretty simple mod to an existing C clamp?
  #37
Old 01-21-2018, 03:19 PM
1 Turned top for the ram that slides on
2 Made the lifting arm from 1/2" T-1 steel
3 Done except for springs maybe someday
4 Ready to lift
I see they put your toe jack on homemadetools.net
  #38
Old 01-26-2018, 06:01 PM
monckywrench's Avatar
trust but verify
I didn't know the visegrip trademark owners stopped making them.
You could split a C-clamp then install the flat bar and a slider, but I'd modify a visegrip instead to what you see in the pic and tack ~4" bar a across the adjustment knob for extra leverage. Once you T-bar your visegrips you won't miss the knob and besides saving your hands the T-bar allows MUCH more force to be applied installing or removing the visegrip.
Another handy way to use those clamps it clamping the end of the flat bar in your vise.
I like those toe jacks even more now. The return springs were a fine time saving idea.
  #39
Old 02-01-2018, 02:55 PM
With a Toe Jack, you only know you've ever needed one when the situation arises to where it gets used and you would have had nothing else without fret and worry to deal with.
Well done on the build. Nice.
Now here's the rub I find with screw type clamps or visegrip type clamps. Seems no one but me can use one without over-stressing it's single ability. At work I'd bet money you would not find once c-clamp without it's tee rod for twisting is not bent to the point where it will not slide through it's attach hole. sigh. 2" to 24", bitches be bent to shit. Same with our table vises. Seems like a hammer or cheater is needed to grip on Al.
