Old 02-06-2012, 08:36 PM
David R David R is offline
Default 4:00 walk in
I was working on my grill when phil showed up with some parts and blue prints.
I used 3/8" x 4" I had a 12 foot piece of in stock. 2 10" pieces
I used the sample to guide my torch both sides.
V350 pro with advanced panel Bunch of other Lincoln machines Hypertherm 600 Arcmaster 185 Estwing BFH
Enough knowledge to get into trouble
Old 02-06-2012, 08:46 PM
NC Fabricator25 NC Fabricator25 is offline
Well, I have no idea exactly what it is, but I'm loving the blueprints!
Please fill us in on the details and more pics as you progress (you may be in the middle of posting, so I'll check back in a while). Looking good!
-David
Old 02-06-2012, 08:48 PM
I drilled some 1/4 inchish pilot holes then 7/8". I have a set of those bits that look like end mills they are with my son
to cope tubing for his senior project.
My dad gave me this drill press. Its the balls!
I used a lever to make sure things were square. Who was asking about Two hole? I just held the level at the bottom of the 2 holes. I used a portaband to put the chisel point on the 1" threaded rod.
I stopped and asked my customer if they needed clearence for the flanges. I made them a little different than the drawing.
Here are the welds, arcmaster 185 not a clue how many amps. I tried not to over heat the filler. 1/16 tungsten, 1/16 filler.
Many passes
Delivered still hot to the customers back at 6:00 PM. About an hour and a half.
Old 02-06-2012, 09:27 PM
Harvuskong's Avatar
The Enforcer
EEK, a clear violation of the picture posting guidelines.
Cutter will be along soon.
Biden & Harris is our enemies favorite candidates
Old 02-06-2012, 09:48 PM
what did or didn't i do?
Old 02-06-2012, 10:00 PM
Scotts Scotts is offline
There is more than 1 way to post pictures. If I remember correctly these are attached and not embedded. Our picture posting is different than others and we attach and host onsite here and do not use offsite hosting like the other sites I have heard of. ( yes there are other sites, I hear of them from time to time) If you scroll down when you reply you will see a blue link where the picture is in the post. It shows it is attached to our server.
Usually all the pictures are posted 5 at a time at the bottom. This is just a different style of attachment. Still attached and hosted at SFT That way the thread will still be viable as long as SFT is up and running.
I did not see who all was online so I put this out for now. I am subject to learning new things as well.
Please continue to post pictures it looks good.
Have you done a series on your belt sander?
Old 02-07-2012, 06:36 AM
http://fudpucker.smugmug.com/Other/W.../0/L/015-L.jpg
Like this?
its an embedded link i think, I am a welder, not much of a geek.
I copied the link and pasted it to the globe and chain thing above.
David
I don't get it, delete the whole mess if you need.
Old 02-07-2012, 07:52 AM
flametamer's Avatar
David
There isn't anything wrong with your pics. It's just not as common to see them that way. It is an accepeted way of posting pics though. So all is good.
Did you find out what the pieces are for?
Dt
Sero Sed Serio
Acta non verba
Old 02-07-2012, 09:46 AM
Yes, they are pipe jacks. They do not fit because I was asked for 7/8 holes. They need one inch. Out comes the Dewalt hole stretcher.
I found this out at 7 am.
David
Old 02-07-2012, 11:20 AM
Scrapper Greg's Avatar
7-26-1965 to 6-5-2022
Nice build. Welds look great. Also its a whole lot better to need 1" hole and drill them 7/8" than the other way around!!!
MAGA
