Drawing by Smartdraw |
It was built once before. You can do it again. The more challenging part might be deciding if it should be heat treated or not.
You might be able to face off the piece with the gear flat, drill a 1/8”- 3-16” hole, and then weld on a new shaft, that has a nib that centers it into the gear. I would leave the shaft oversized, for turning true to the gear after welding. If you can get almost 100% penetration, it would probably hold up. And you have learned what not to try to lift now. Since you modified the motor to runit in the first place, I am confident you can pull off this repair. I’ll try to draw a picture to better explain this. Sent from my iPhone using Tapatalk
Brian You don't know what you don't know. ![]() "It's what you learn after you know it all that counts." John Wooden ![]() Last edited by toprecycler; 11-23-2022 at 07:39 PM. |
That would save a lot of work. That shaft is super hard, its worth a shot
If anyone can make it work Ted/Digger can
Thank's for the confidence!
The shaft is only .785" next to the sprocket to allow clearance for the chain. If I go for it I would chuck the sprocket end in a four jaw and chuck the add on using a drill chuck holding the oversize add on n the tail stock and weld it in the lathe, then cut off and drill a center hole and finish turning. What do we think?
Did you preheat the 4140?
Biggest part will be leaving the shaft slightly oversize so you can turn it true afterwords. Preheat probably would be a good idea too. Although, I am just starting to realize how important it is, and have to think that this might be a reason as to why we have had some part failures in the past at work. It is hard educating "the welder" when he thinks he knows best.
Before welding, yes. After, when installed it would fail in a bit less than a year. It was a pin on a oscillating axle.
