![]() However, I have a project in mind that I think I want to try and I think their technique might come in handy. The glue shelf at HD doesn't have any Youtube Superglue Spray. Does anyone have product recommendations on what to order? |
Heat helps make superglue set faster, but if you want quick speed try this stuff. https://www.amazon.com/Starbond-Inst...29976035&psc=1
CHEAPER.... https://www.ebay.com/sch/i.html?_nkw...a35e3332731442
Let FAITH be bigger than your FEAR. ***** Pray like everything depends on God, and work like everything depends on you. ***** The world is changed by your example, not by your opinion. --St. Mother Teresa ***** In life it's important to know when to stop arguing with people and simply letting them be wrong. Last edited by Tim KS; 11-15-2022 at 11:59 AM. |
Baking soda will speed up the setting time. It can also be used to build up where pieces are missing. Just dust it on or fill the holes with the powder.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
I've always used this stuff
https://www.amazon.com/Pacer-Technol...23790456&psc=1 It's not so much that it is faster, but it will make the glue dry in situations where it wouldn't normally dry. Like filling a gap, or making it dry before it has time to run out of the bond line. It makes the glue real hot though, you don't want to have some glue on your hands and hit it with this stuff, it will burn you. Don't ask me how I know that ![]()
Director of Sarcasm (by appointment) Director of Innuendo (by suggestion) |
![]() Now that I've read up a little on this stuff, they also talk about residue. In the DIY video with the alcohol/baking soda, I can see where it would come from. Wondering how well that cleans up after the cure? While it isn't a big deal if the actual joint is a little dirty or cloudy, I don't want a big splash of stuff showing up elsewhere. I did see that you could easily use it as a "drop" for more precise application so that's an option. |
I did not watch any of those videos but I have used a lot of cyanoacrylate glue before and there are some things I know about it.
Number one, protect your eyes from the fumes! They burn like an MF. Number two, this glue cures when you remove the air. It works best with a tight fitting joint where you can squeeze out every bit of air and every bit of excess glue and once you do that, it cures very rapidly. |
According to the dude in the How-To video, it actually cures due to water. Humidity in the air is "usually enough" to get the process working. His mix consisted of 70% alcohol and baking soda.
I have never had CA glue dry as fast as it has always seemed to on the commercials. Makes sense that humidity could play a part in that. We don't have water in our air out here. |
Here is todays chemistry lesson. https://youtu.be/1hY1jyGNzIo
I think he said that you need moisture, but other things work also. |
