Old 10-29-2022, 06:54 PM
engineman56's Avatar
Nutbuster
Default The Post Hole Digger
I think this is more mechanical and a little fab. So I'm going to put it here.
So I bought this Post Hole Digger off Marketplace. It ain't all there, so it was cheap. You all know me. I'm cheap. But I'm not easy. But I can be tricked. Lol
Anyhow, I got it home. Now I'm going to mount it on the 52 DC.
So I get started.
At this point, I'm figuring out the range of motion.
So after I get that figured out, I need to put a slight bend in the lifting arm. Dad says, "Just get the torches out and make it fit."
Ok here we go! Click image for larger version
ID:	166043Click image for larger version
ID:	166044Click image for larger version
ID:	166045Click image for larger version
Sent from my SM-S901U using ShopFloorTalk mobile app
Old 10-29-2022, 07:01 PM
Nutbuster
So I get these washerscut out for wear. Cause the channel I have was thin. I was ramming holes with this little drill press I bought off eBay.
I'm well aware of the dangers of that drill press because my Dad has one, and I used it when I lived at home. And I've been bloodied up with it a lot of times. But it works well and I like it. I'm a dangerous person. Lol, according to some. Lol
ID:	166047Click image for larger version
ID:	166048Click image for larger version
Old 10-29-2022, 07:14 PM
Nutbuster
So here I go with the mock-up. What a pita.
So I get it figured out. Low point and high point lift arm length and all that Rigama roll. And let's not forget all the fancy welding and things that go with the calculations. LolClick image for larger version
ID:	166050Click image for larger version
ID:	166051Click image for larger version
ID:	166052Click image for larger version
ID:	166053Click image for larger version
ID:	166054Click image for larger version
ID:	166055Click image for larger version
Old 10-29-2022, 07:17 PM
Nutbuster
So I waller around on the ground, welding it together. I get it. I'm good with it. Now I'm checking it under Power. That's cool. I like it.Click image for larger version
ID:	166057Click image for larger version
ID:	166058Click image for larger version
ID:	166059Click image for larger version
Old 10-29-2022, 07:21 PM
Nutbuster
So test time! I go down to the area where I am building the cow pen. I drill the first hole. The dirt is kinda hard. I knew that I dug the holes by hand for their building many years ago. Now I'm setting up the outside pen for them. Click image for larger version
ID:	166061Click image for larger version
Old 10-29-2022, 07:27 PM
Nutbuster
It did work well except for the fact that the soil was all clay down about 18". But that's only in places. It might be ok.
Old 10-29-2022, 07:28 PM
Nutbuster
This is the very first project I have done in a very long time. And it's for me.
Old 10-29-2022, 07:47 PM
Look out, SFT Kevins back and he's "Dinking Around" with dangerous projects and toys again
Old 10-29-2022, 08:12 PM
Gear box full of oil?
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 10-29-2022, 08:40 PM
Nice project Kevin!
