Old 07-18-2022, 03:45 PM
Oscar's Avatar
Oscar Oscar is offline
Default Angle Grinders: Corded vs Cordless vs pneumatic
Just a hunch but I'm guessing this crowd is mostly fans of the corded variety. But if anyone is a fan of cordless and/or pneumatic, I'd like to hear about the units you use and how you like and/or dislike them.
I myself have all 3. Naturally, like the rest of you, I acquired corded grinders earlier on, but have since grown to like cordless and especially pneumatic. My corded grinders are cheap Ryobi's rat-tails that are relatively low-powered, but have withstood good use. My cordless are harbor freight Earthquake's that I purchased cheap when my local store was phasing them out when they were discontinued, and I have tons of pneumatics from 3" adjustable speed angled die grinders, to 7" economy grinders I got from Ebay.
Old 07-19-2022, 07:53 AM
Banned
So you have "cordless Pneumatic" grinders ???
Old 07-19-2022, 08:25 AM
I have some 7" fence post drivers, or 1 ton grinders, but use them so little that I have tried to give them away.
I have a cordless grinder, but good as it is, battery life is short and recharge is long. Sort of like a EV. I have found that it's use is as a cut off. With a .049 disc it is a very useful tool.
My main go to grinders are corded Milwaukee 4 and 5 inch grinders. They will get the job done quickly.
I have used pneumatic's, they have little torque and need to be kept at higher rpm than electric corded. Generating compressed air is costly and not a good way to go. Die grinders are the exception, they are very useful in some applications.
Old 07-19-2022, 08:32 AM
Similar here, my actual grinders are a 4.5” makita, several 5 and 6” grinders of various makes, a couple big old 7/9” black and deckers with the all metal bodies that I rarely use.
No pneumatic angle grinders, I’ve got rid of any I’ve ever been given without even trying them.
1/8” and 1/4” die grinders, likely have close to a dozen, some of my jobs in the past these were the tools in hand sometimes an entire day or more at a time.
There’s also some bench grinders, and a surface grinder in the mix of ‘grinders’. Again, depending on the day the surface grinder can be in use for hours at a time.
Old 07-19-2022, 08:36 AM
Twice the size--half the man
Yep, corded electric here. I burned up 3 DeWalts early on, but I was buying them below wholesale cost so it wasn't too terrible. Even saving a bunch of money at the time got old when the tool broke mid job.
The dream was to go for the Metabo units, but I never made it that far. Now I don't know that I'd trust them since they realigned with the Hitachi group. I broke a gear out of a Hitachi one about a week into it's use as a replacement for one of the DeWalts.
I swapped to Makita and had both a button and a paddle style. The button one got stolen, never cared much for the paddle. Tractor Supply had a sale on a Porter Cable one afternoon so I grabbed it, and it's now the go-to machine. However my needs for the things have declined tremendously and I think I've used it twice since taking it out of the box.
I do have an old Ryobi unit that I put a twisted wire wheel on one afternoon and have yet to be able to break it back loose--so when I need the wire brush I grab it. One of these days maybe I can see if it's useful for something else.
I've had a number of pneumatic die grinders through the years as well, but mostly I just use my dremel these days. The projects I take on any more are light enough that it gets the job done just fine.
Wade's Custom Kydex
Old 07-19-2022, 11:24 AM
Oscar's Avatar
No, you read that out of context, likely on purpose for some unknown reason. Pretty much everyone else understood exactly what I was talking about and replied accordingly. You on the other hand.....
Old 07-19-2022, 11:47 AM
I have probably at least dozen grinders. Several 1/4” pneumatic air die grinders.
No bigger pneumatic air grinders, other than a DA sander.
I have one cordless grinder, 4”. I bought it to go with current drill and battery I had, but went for the value dollar line. It is a porter cable. I also bought a 1/2” impact for this line too.
It is handy for when I need to do a quick job, that one battery can do.
Other than that, I have several grinders, each with dedicated wheel setups. Cutoff Metabo 6”, and various hard wheel, buffing pad, flap disc., wire wheel, etc Only change when they wear out.
Old 07-19-2022, 11:55 AM
Give the man a prize
Old 07-19-2022, 12:16 PM
Banned
Nope, I didn't take anything out of context.
I'm not a mind reader.
Your just an idiot with a phone.
Old 07-19-2022, 12:40 PM
Oscar's Avatar
Looks like you're not an anything reader. So that makes you the idiot by my perspective. So just go ahead and F-off and go prance around somewhere else
Thank you to those that actually answered in the spirit of having a discussion.
