Old 05-17-2022, 03:05 PM
Twice the size--half the man
Default Regulator "blow hole"
I've not used my welder in almost a year. Did a little job to patch a chair a week or two back, and sometime during the process the regulator developed what I thought was a leak. I thought maybe the hose had gotten a hole in it. I didn't notice it during the work itself, weld seemed good, was getting gas at the proper level, etc.
I realized it when I went to purge the machine after I was done. When I went to turn off the bottle I could hear it hissing and noticed that the 'regulating' gauge was pegged wide open. The other dial showed the pressure in my bottle as always.
Dug the crap out from around the bottle to get to it last night and actually examine what was going on. Felt around with the bottle open thinking it might have been at a fitting, only to realize that the gas is spewing out the hole in the side of the regulator valve.
So, long story short--what's wrong with my regulator and how do I fix it? How do I even get it apart?
ID:	164679   Click image for larger version
Wade's Custom Kydex
Old 05-17-2022, 04:32 PM
It may be repairable but the cost would not be worth it. Best to get a replacement and this time get one with the rising ball type of flow indicator.
I have several like that they seem to stuff them in every welder you buy and I put them on a shelf and get a real flow meter
Old 05-17-2022, 11:54 PM
Blown diaphragm. You should be able to get a replacement diaphragm, needle etc. from Victor or Radnor or wherever your regulator came from. The top unscrews from the base and the diaphragm cover does the same.
Old 05-18-2022, 09:38 AM
A quick search of the model number says it's a Victor and a parts kit is $40.
Amazon has a whole host of the rising ball type meters at stupid cheap prices. Is there a type or version that's best to look for? Besides the ones on my old air compressors, this is the only regulator I have had for gas bottles. Hell, it's still the only gas bottle I own.
And naturally it goes bad when I actually have a job that won't pay for the replacement of the part
Wade's Custom Kydex
Old 05-18-2022, 07:58 PM
Do I have a life?
Last kit I got on debay for $15. OEM kit. I think mine is an AF200 or 250--I'd have to look. Anyhow, if that is the "little" guy, it might be worth it to just get a new one. I picked up an open-box Vulcan? at HF for $20 so there are "deals" out there.
This is probably the kit I got several years ago. LINK I don't know if it will fit yours.
One part that goes bad is the seal between high and low, I think it is number 9. That will show as the low gauge winding up all the way when you open the tank valve. The diaphragm is number 6. That might be your leak.
You should first try getting it apart before you go crazy ordering parts. Be careful not to snap the gauges off. The diaphragm cover screws off but it can be super tight...
The "T" handle low pressure adjuster should NOT be turned all the way in! If fact, after you bleed the gas out, you should back out the T until it is loose and no longer pressing on the diaphragm.
HF 80 lunchbox w/tig
Old 05-18-2022, 08:14 PM
All I'm seeing are Chinese and for the price will be ok. They are dirt simple inside and more accurate than are the pressure type attempting to regulate flow. The ball rises in a slightly tapered hole the becomes larger the higher the ball rises.
I have a supposedly north american regulator that looks exactly like the Amazon ones and probably came out of the same shop. It has never failed. I have had my Victor oxy and fuel regulators rebuilt 5-6 times over the last 30 years or so.
I like this design as the gland around the adjusting knob can be snugged up to provide resistance so you don't knock the adjustment out when reaching to shut the tank off. The other type with the side adjustment knob is easy to hit.
Old 05-20-2022, 01:36 PM
+1 on what AZ said.
Old 05-20-2022, 01:38 PM
The rising ball is known as a flow meter. They have diaphragms that can go bad too.
Old 05-21-2022, 09:54 AM
Seems like bad things happen when diaphragms go bad...
Wade's Custom Kydex
Old 05-21-2022, 11:33 AM
astronut's Avatar
astronut astronut is offline
Thats what she said!
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
