SFT Search: |
Thread Tools | Display Modes |
#111
![]() It's transcending the first time you get to do pulsed spray. Sent from my ipotato
The guy that said money can't buy happiness never bought a tank of fuel for a turbo diesel............. |
#112
do a couple of timed runs on the same part then do an acid etch test.. they really don't compare.. Spray arc is so much faster with less HAZ, better penetration, better finish.. I'll come and poke him in the eye for you.. ![]() Just so you guys know I have never poked someone in the eye because I don't like what they are saying. I just like to think about poking them in the eye while they are saying it.. ![]()
_________________ Jennifer If I defend myself I am attacked. My meaningless thoughts are showing me a meaningless world. My attack thoughts are attacking my invulnerability. I'd like to think of something smart, but I don't want to hurt myself. ![]() My google+ page DoALL 36" Another Johnson model J Project Lathe? Maybe..... 1958 SBL 13" Yeti Esseti Aka running welder on 3phase. https://www.shopfloortalk.com/forums...860#post766860 |
#113
The Miller MM350P was probably one of the best buys, I ever made.
jack |
#114
And I'll bet Miller never tried to advertise it by telling you it was magic.
"It's not important how many people I've killed. What's important is how I get along with the people who are still alive." - Jimmy the Tulip |
#115
Bingo!
jack |
#116
I wonder how the machine Pile Buck had has held up over the years ?
#117
Here is a link to a youtube video of our Plasma-Tec50dv cutting 3/4 inch steel bottom plate for an excavator bucket we built in a day. It's quite a long continuous cut. https://youtu.be/g8SBgvvz3HA Viewing it should address your comment... "I'd like to see a video of you cutting 3/4" steel...." This video does show the front of our 20 lb machine for a short time... FYI: really the duty-cycle on our machines are virtually 100%... literally we have never had a thermal shutdown. I mean the MOSFET heat-sink is ambient temp. to the touch of a finger and stays that way. It really comes down to MOSFET switching transition speed (the time it stays between on and off (heat generations zone)) and the Ron (Resistance of the MOSFET when switched on). This is another reason I've stayed with Power MOSFET's. But, I do need to check for tech. advancements of IGBT's as there are pro's & con's for both. I suspect your Powerbax45 is producing around 700+ watts more at the cut than my Plasma-Tec50 since you state it will easily cut 1 inch... and my machine is slow at that thickness. It seams that higher cut load voltage is a benefit... but, I suspect there is a sweet-spot between output current and cut load voltage. Quite interesting. I have measured voltage under load before and it's around 115 volts and does vary a bit. But, I can test it again. Plasma chamber: I meant for example our PT31 torch has consumables with different sized plasma chamber in the tip... and the AG60 torch (being used in the video) has a much larger plasma chamber. None get very hot. |
#118
#119
![]() Mac, it's too bad Jimmie did not have his hooked up for steel when you were out this way.. Pretty impressive..(upgrade available over the net too..) highly adaptive arc in pulse. First thing Kevin said when he used it beside his 350p..
HARLEY-DAVIDSON: "THE MOST EFFECTIVE WAY TO CONVERT GASOLINE INTO NOISE WITHOUT THE SIDE-EFFECTS OF HORSEPOWER":evil: |
#120
For that speed and quality of cut I'll stick to O/A.
As a multi-process machine, it looks like it does many things, but none of them really well. Which is why I'll stick to dedicated process machines. Sent from my iPhone using SFT |
Tags |
plasma, plasma cutting, stick welding, tig welding, welding |
