SFT Search: |
Thread Tools | Display Modes |
#101
If your unit was as good as you say it is, this could be an opportunity for you. I am typically a miller lover on welders, and Hypertherm on plasma. But I do keep an open mind, and I will be in the market in the next 3 months. As far as trustworthiness, I think it is somewhat insulting that you would not trust the owner of this site who has been operating it for quite some time. I'm sure contact information could be exchanged to ensure proper return of your unit (if it didn't sell onsite).
I believe the appropriate metaphor here involves a river of excrement and a Native American water vessel without any means of propulsion. |
#102
Sent from my ipotato
The guy that said money can't buy happiness never bought a tank of fuel for a turbo diesel............. |
#103
Jim... thanks again for sharing the technical and practical information about your Hypertherm machines.
Those 5/8" steel cuts at 60amps we're fast and clean. Very impressive! I think you stated that machine has a voltage at the torch of 136 volts under cut load... compared to my 60amp which has 115 volts at cut load your machine I roughly calculated yours is producing about 1200 watts more cutting power than mine. And like you said torch design is important as well. It looks like your machine has a very large plasma chamber. Sure was impressive performance! For industrial use it is apparent a machine of that power is what is needed for thick, fast, clean cuts. I think the multi-function of Plasma/AC-DC TIG/Stick and enough power to get through 3/4 inch coupled with the low cost makes more sense to a DIY, small business customer. However, I do agree that for industrial use your machine is the obvious choice for plasma cutting. I was also very impressed with it's ability to cut expanded metals by switching between high current cut and low current pilot arc modes when the torch is over a hole of other void. Does the pilot arc mode produce any electromagnetic interference? With regard to your comment about mult-process functions (Plasma/TIG/Stick) in the same machine not being able to be optimized. I'm really not sure what you meant. The multi-function design used in our machines do not affect reliability or performance in any negative way... as it is effectively that same machine weather in Plasma or Weld modes since either mode uses the exact same components. The specific design really is a technical WOW! FYI: For those interested in AC TIG (Aluminum) welding. I have installed technical embellishments to allow extremely precise thin welds. As a best case test I was able to weld the end of a soda can which is 0.0035 inch thick. That was quite an experience as it felt like I was pouring aluminum (resin) out of a bottle. I plan to post some video of welding thin Aluminum... and thick as well. Also will post video of stick welding thin steel. Since the current regulation is so accurate it is easy to use any size rod to weld thin sheet without sticking or burning through. I seems to always doing 45 things at once but, I will try to make posting those videos a priority. I should have made them long ago. I've emailed God, asking for 28 hour days... still waiting for reply. ![]() With regard to the extremely low cost of our machines... I suspect that China does not make a "real" profit and are more interested in snagging market share for the sake of domination. That behavior can be considered unfair... but, it does have a positive side-effect in that my customers get to keep allot more money in their pockets and still afford a machine that does much more that anything available from the USA. It's a great benefit for small businesses like mine... as it allows me to compete with the larger companies. Jim, thanks again for a great post. |
#104
A large plasma chamber? Maybe you can explain? And trust me....your machine is rated (duty cycle) at 115 load volts, but you will not be cutting 3/4" steel at 115 volts....most likely with an unshielded torch your load voltage will be at least 130 to 135 volts. Your power supply will produce that voltage for a short period of time....until duty cycle is exceeded or failure occurs.
The pilot mode is simply lower power.....but the ability to switch from cutting power to pilot, then back to cutting very quickly without going through the blowback starting process. The level of electrical noise would likely be lower at pilot level. Using our technology a high frequency start torch (like the ones you use) could do the same thing.....without firing the high frequency. I'd like to see a video of you cutting 3/4" steel....lets see the speed, then show a voltmeter showing the load voltage....the wattage would be similar to that of our 45 amp (Powermax45) plasma cutter.....which cuts 1" very well, but at about 145 load volts. Jim Colt Hypertherm Quote:
#105
So then I'm not going to get to try one of these out next week?
Will there be a Millermatic 211 and a Powermax 45 available? My heart wants a 350P, but my wallet probably won't let me have more than a 211 ![]()
#106
#107
Hey, I wanted to try your 350P. Then I can see what I am missing at work. Oh wait, I probably would never talk the boss into one. I started using spray arc last year and he just asked/ told the other guy he is not sure it is worth it and we better do some tests to make sure it is as good as short circuit. :-) what do I do? The boss is always right, right?
#108
My experience is different...
#109
Yeah, that only works when you're self deployed...er, employed..
"I was raised with you do things because its what you should do. I never expected anything in return." -----DozerDan |
#110
Go ahead, we can store it in my trailer when were not using it....:shifty:
Tags |
plasma, plasma cutting, stick welding, tig welding, welding |
