Not just for a bolt hole but quite a few times I needed a "clean hole" the same size as the drill bit and did not have a reamer. basically using a drill bit as a reamer works well most of the time and the hole comes out true to the bit size. use the same procedure as if you were reaming but use the drill bit when a reamer is unavailable. the better the quality drill-bits, the better the hole comes out. side note: the truer the bit runs the better the hole.
If you want ‘exact’ than drilling still isn’t the way to go. Reaming is closer, for really tight fits lets talk jig grinding, honing or wire edm. Not sure what your ‘real world’ is, but I’ve been making chips for 30 years in one form or another. Red seal tool and die maker by trade, and been working as an on site/portable machinist the last three years. When you start fixing stuff that has a ‘shop rate’ of $100K an hour we’ll talk. Sent from my iPhone using Tapatalk |
Yep, you’re ‘reaming’ the hole, just with a drill instead of a reamer. We used to call it ‘drill-reaming’ as a matter of fact. What it will often do though is give a slightly tapered hole, maybe only a couple tenths difference, and for 99.9% of shop and home applications it isn’t even noticable. The finish depends a lot on the drill, and I’ve used the power feed on mills etc, along with a slight amount of drag on the quill from the quill lock to prevent it grabbing from backlash in the quill feed. Sent from my iPhone using Tapatalk |
In earlier post, I’ve talked about my Chinese sourced deluxe drill sharpeners, I don’t use it often, but when I do it works great.
https://www.shopfloortalk.com/forums...r-26+sharpener
jack |
So how about you? Tell us a bit about yourself...time to put up or shut up... ![]()
When you live in the 'universe' there is a lot more room for a swollen head.
A second candidate for an "Ignore list" . :-)
...lew... |
Well, I've been learning by actually doing since 1966. By doing, not by listening to people like you or looking up charts and books to see what speed I need to turn a given sized piece of metal. I started as a welder and branched out into machining, sheetmetal worker, bricklaying, pipelaying, training police dogs and so on. By the time I retired 20 years ago, I had been in management for 10 years with over 30 people working for me.
I don't claim to know everything, but what I do know is from actual experience. But you guys are set on your course of patting yourselves on your backs and telling yourselves that no one has right to a different opinion than you. Anyway, I'll leave you lot to bath in your misplaced self glory, nothing of any interest here for me |
I go away for a short period of time and all hell breaks loose!!
WTF is going on??
jack |
