'from sapling size to 5-6inches in diameter"--thats gonna require horsepower and machine weight no matter how you power it or move it once cut..best approach if you have the money is to use a Fecon mulcher attachment to cut and mulch it in one pass..yeah,its gonna cost $$$$ money..I tried to do it on the cheap too but soon realized it a compromise could be made..If you do want to economize on the job then get a tracked skid steer(compact trackloader) with a top-clamp grapple rake and go at it..dig out,lift and stacks everything..culls out larger rocks and stumps too. We used a Cat 277 and got great results with it.
Mig, Tig, Saw, Heat, Plasma, Turn, Bend, Grind and Blast Lift, Load, Push, Compress, Generate, Illuminate + Elevate Not Enough Room to do it all..at least at the same time. |
You don't want to spend the rent money ? Recall you'll only doo it once, and then every year, use a simple tow behind brush mower to keep it in check. FWIW ask over at HeavyEquipmentForums.com the drum style seems to be taken over by the disc style. At least that's what's being said by the user over there, that use them all day. https://www.youtube.com/watch?v=HrXzrcNQJcc Last edited by digger doug; 05-28-2019 at 09:49 AM. |
1. engine way too small 2. carbide tipped blades don't like to play in the dirt 3. belt drive will slip when wet (no, we wouldn't get the belt wet now would we ?) 4. Pinching a 7" tree will bend the blade, and ruin the contraption. |
I saw this last year in the local P/A store with a "make an offer" sign on it. My first thought was WTF???
That whole front end is gonna be toast shortly....
http://www.edinburgauction.com/lot/3...-brush-cutter/
Maybe copy some of the idea in a scaled down version.
Due to the lack of effort today Tomorrow has been canceled................... |
BTW I got a good look at one of those one day, do you know what the hourly rate is for those ? and what do you think the greenies would do, if you hauled one in ? |
